[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Markus Metz
markus.metz.giswork at gmail.com
Mon Oct 9 13:07:15 PDT 2017
for the record, the problem is that for Corine Land Cover 2012, the
Coordinate Reference System embedded in the raster data is
LOCAL_CS["Geocoding information not available Projection Name =
ETRS_1989_LAEA Units = meters GeoTIFF Units = ot",
UNIT["unknown",1]]
while it should be
PROJCS["ETRS89 / LAEA Europe",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3035"]]
Apparently the creators of the data tried to hide the Coordinate Reference
System in the GIS data available for download.
Markus M
On Mon, Oct 9, 2017 at 7:13 PM, Hakim Benoudjit <h.benoudjit at gmail.com>
wrote:
> You're right I wasn't using the gdal commands that come with OSGeo4W
(with that version of gdal it's working well), I was working with a version
of gdal that I've compiled from source. So probably some flags had to be
set during the compilation, but I forgot to do so.
> Hakim.
> On 9 October 2017 at 17:54, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> Hi Hakim,
>> On Mon, Oct 9, 2017 at 6:36 PM, Hakim Benoudjit <h.benoudjit at gmail.com>
wrote:
>> > Thanks Markus for your reponse.
>> > I tried the gdalwarp command to reproject the land cover raster to
WGS84 using the following command:
>> > > gdalwarp -s_srs EPSG:3035 -t_srs EPSG:4326
C:\Data\Corine-Land-Cover\g100_clc12_V18_5a\subset.tif
C:\Data\Corine-Land-Cover\g100_clc12_V18_5a\subset-wgs84.tif
>> > But I'm not sure how to provide the csv file it's asking for to
interpret the projection:
>> > ERROR 4: Unable to open EPSG support file gcs.csv. Try setting the
GDAL_DATA environment variable to point to the directory containing EPSG
csv files.
>> > The only csv file provided with this land cover archive is inside the
Legend folder (clc_legend.csv), which gives the index of each type of land
cover.
>> > Do you have any idea where to locate this gcs.csv file it's asking
for, and how to provide it on Windows (should I add an environment variable
set to the path of this file)?
>> this gcs.csv file is part of a standard GDAL installation. GDAL uses by
default its own gcs.csv file, there should be no need to specify this file
or GDAL_DATA explicitely.
>> It seems that something is wrong with the GDAL installation. Are you
using gdalwarp from OSGeo4W?
>> Best,
>> Markus
>> > Hakim.
>> > On 9 October 2017 at 17:23, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> >> On Mon, Oct 9, 2017 at 4:37 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
>> >> > Hi Hakim,
>> >> > Try r.import (https://grass.osgeo.org/grass72/manuals/r.import.html
>> >> > ETRS LAEA (EPSG:3035) is of course “supported”.
>> >> True, but a coordinate reference system not included in the input
data, therefore r.import will not work and you need to define the CRS
(EPSG:3035) manually.
>> >> Markus M
>> >> > Cheers
>> >> > Stefan
>> >> > From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On
Behalf Of Hakim Benoudjit
>> >> > Sent: mandag 9. oktober 2017 16.02
>> >> > To: grass-user at lists.osgeo.org
>> >> > Subject: [GRASS-user] Unable to open the Corine land cover map
using GrassGIS 7
>> >> > Hi,
>> >> > I'm unable to open the Coring Land cover map (100m accuracy
version) for Europe using GrassGIS, which can be downloaded from
http://land.copernicus.eu/pan-european/corine-land-cover/clc-2012.
>> >> > Apparentely the coordinate system of this land cover map isn't
supported (The projection is ETRS89 (EPSG:3035)), while the projection of
the location I'm trying to import the raster to is WGS84 (EPSG:4326). Here
is the error shown in GrassGIS: ERROR: Coordinate reference system not
available for input <C:\Data\Corine Land
Cover\g100_clc12_V18_5a\g100_clc12_V18_5.tif>
>> >> > Is there a workaround in GrassGIS to open this image?
>> >> > Otherwise which tool should I use to reproject it?
>> >> > Thanks.
>> >> > Hakim.
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171009/8585e014/attachment.html>
