[GRASS-user] How to add all vectors to display
balotti.and at gmail.com
Wed Oct 11 01:57:12 PDT 2017
Hi Robert,
Using the GUI there is a button (shortcut: Ctrl+Shift+L) to add
(all/some) layers to the layer tree.
Using the CLI probably the best way is a loop of "d.vect" over the
output "g.list type=vect"
Best regards,
Andrea Balotti
Il 11/10/2017 09:19, Robert Kuszinger ha scritto:
> Hello!
> Is there a method to add all vector maps to the layer manager
> automatically in a mapset?
> I have > 70 of them and I don't wnat to add them 1 by 1.
> If there would be a command for d.addvectorlayer map=this,that,etc....
> default black line is enough...
> GRASS 7.3.svn (Adree1):~ > g.version -rg
> version=7.3.svn
> date=2017
> revision=r70991
> build_date=2017-05-04
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> libgis_revision=70829
> libgis_date="2017-04-04 09:43:02 +0200 (Tue, 04 Apr 2017) "
> thanks
> Robert
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171011/79b016ec/attachment.html>
