[GRASS-user] Patching rasters based on other rasters
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 17 04:41:52 PDT 2017
Le 17 octobre 2017 13:38:34 GMT+02:00, Ken Mankoff <mankoff at gmail.com> a écrit :
>Dear GRASS List,
>I'm trying to do something in GRASS and can't figure out an efficient
>way to do it. I'm guessing it is possible with 1-3 lines, but don't
>know which ones. The algorithm I'm developing would be much more
>complex, and I hope someone can suggest a shortcut.
>I have several satellite products of the same region each day. For
>simplicity sake lets assume 3 overlapping solar zenith angle (SZA)
>products, and for each of those a visual image (VIS). I'd like to have
>one visual raster that, for each pixel, has the minimum SZA.
>I can get the minimum SZA for each pixel with
>r.mapcalc "SZA_min = min(SZA1,SZA2,SZA3)"
>But now I've lost the source of the minimum SZA, and I need it to link
>SZA1 with VIS1.
>I could encode categories for each SZA:
>r.category map=SZA1 cats=0-360 values=1
>r.category map=SZA2 cats=0-360 values=2
>r.category map=SZA3 cats=0-360 values=3
>And then
>r.mapcalc "SZA_min_cat = min(@SZA1, at SZA2, at SZA3)"
>And then use SZA_min_cat (values: 1 to 3) as a lookup to
>VIS1,VIS2,VIS3. I'm actually not clear how to do this last step, if
>this is the correct approach. Do I return to r.mapcalc, or is r.univar
>the right tool?
>Any help will be much appreciated.
Check r.series, notably the min_raster method.
Moritz
>Thanks,
> -k.
>_______________________________________________
>grass-user mailing list
>grass-user at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/grass-user
