[GRASS-user] Problems getting unique categories with v.category
Eric Patton
thepattonian at gmail.com
Thu Oct 19 11:38:05 PDT 2017
I have created a point vector from a coastline using v.to.points:
v.to.points input=CanCoast_Shoreline type=line
output=CanCoast_Shoreline_points
use=vertex --v
This works fine, and the next thing I want to do is upload raster slope
values from a DEM to the attribute table of the points vector using
v.what.rast, but I get tons of warnings like these:
WARNING: Multiple points (12) of category 16, value set to 'NULL'
I assume this is telling me the points have duplicate categories?
So to get around this, I tried recreating the points, this time without an
attribute table, using v.to.points -t, then adding the table and categories
manually:
use=vertex -t --v --o
v.db.addtable map=CanCoast_Shoreline_points columns="Slope_percent integer"
v.category input=CanCoast_Shoreline_points option=add
output=CanCoast_Shoreline_points_with_cat
But running v.what.rast still gives me the same error as before.
I ran v.categories in report mode to see what is going on:
v.category input=CanCoast_Shoreline_points_with_cat option=report
Layer/table: 1/CanCoast_Shoreline_points_with_cat
type count min max
point 105427 1 1692
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 105427 1 1692
Layer: 2
type count min max
point 105427 1 105427
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 105427 1 105427
Where did the two layers come from? I thought v.to.points -t *wasn't*
supposed to make an attribute table. And the fact that the 'max' value
reported above is '1692' seems to be a hangover from the line features they
were created from.
In this case, I don't care about the IDs or categories of the lines the
points originated from; I want unique categories for the 105427 points that
were made so I can then successfully run v.what.rast and upload my DEM
slope values.
It's been a while since I've used these tools, so I'm a little rusty. Is
there a way to do this?
~ Eric.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171019/3df8db8c/attachment.html>
