[GRASS-user] large shapefile not importing properly with v.import
Helmut Kudrnovsky hellik at web.de
Mon Oct 23 06:49:55 PDT 2017
Markus Metz-3 wrote
> On to the next one:
> On Fri, Oct 20, 2017 at 10:07 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> o World database of protected areas (~ 1 GB):
>> https://www.protectedplanet.net/
> First problems: lots of warnings like
> WARNING: Degenerate island (1 vertices)
> WARNING: Feature (cat
> <XY>
> ): degenerated polygon (1 vertices)
> These are invalid geometries in the input
>> >The real cleaning happens only if the snap option is set to > 0.
> From the WDPA manual:
> "There are many overlapping protected areas in the WDPA. These can be
> overlapping areas with
> different IUCN categories or the overlap of national protected areas with
> designations under
> regional or international conventions and agreements."
> Thus I would not regard all overlapping areas as errors. I used a spatial
> subset for testing:
> v.in.ogr spatial=5.467,43.842,14.3,50.558
> that's the Alps and a bit around.
> v.in.ogr suggests a snapping value in the range 1e-5, 1e-13. I started
> with
> 1e-9 and got rid of the warnings like
> WARNING: Unable to calculate area centroid
> but some incorrect boundaries remained in the output. With snap=1e-8,
> these
> incorrect boundaries disappeared.
> The output contains lots of small areas. According to GIS_AREA in the
> attribute table, the smallest areas in the input are larger than 100
> square
> meters, so I cleaned with v.clean tool=rmarea thresh=100, getting rid of
> 60% of all areas in the output.
> In earlier years, the WDPA was separated into different shapefiles: one
> for
> marine areas, one for IUCN I-VI, one for all other areas. Now everything
> is
> in one shapefile / GDB. When importing these data, a spatial and an
> attribute filter should be set for v.in.ogr.
thanks for also testing this data set. I'll add some notes in the wiki about
importing these datasets.
thanks.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
