[GRASS-user] Merging connected stream lines
Markus Metz
markus.metz.giswork at gmail.com
Fri Oct 27 12:58:56 PDT 2017
On Fri, Oct 27, 2017 at 2:38 PM, Huidae Cho <grass4u at gmail.com> wrote:
> [...] I tried your r.stream.extract to extract stream lines and its
output makes much more sense. It would be great if this module also outputs
unique stream "network" numbers.
Unique stream network numbers are added as new attribute "network" in trunk
r71599.
Markus M
> Thanks.
> Huidae
> On Fri, Oct 27, 2017 at 8:14 AM, Markus Metz <
markus.metz.giswork at gmail.com> wrote:
>> On Fri, Oct 27, 2017 at 12:52 PM, Huidae Cho <grass4u at gmail.com> wrote:
>> > Actually, I'm getting the same error as Markus in the NC dataset. I
recently discleaned and rebuilt the latest SVN.
>> In trunk, this bug appeared with r71267 and was fixed with r71477.
>> In relbr72, this bug appeared with r71268 and was fixed with r71478.
>> Please check your revision.
>> Markus M
>> > Huidae
>> > On Thu, Oct 26, 2017 at 4:14 PM, Markus Metz <
>> >> On Thu, Oct 26, 2017 at 5:02 PM, Markus Neteler <neteler at osgeo.org>
wrote:
>> >> > On Thu, Oct 26, 2017 at 9:58 AM, Stefan Blumentrath
>> >> > <Stefan.Blumentrath at nina.no> wrote:
>> >> > > Hi,
>> >> > > Did you try:
>> >> > > https://grass.osgeo.org/grass72/manuals/v.net.components.html
>> >> > > That might give you a common attribute for all connected lines in
your
>> >> > > network…
>> >> > I just tried that with NC but:
>> >> > GRASS 7.3.svn (nc_spm_08_grass7):~ > v.net.components
input=roadsmajor
>> >> > output=roadsmajor_components method=strong
>> >> > Building graph...
>> >> > Registering arcs...
>> >> > 100%
>> >> > Flattening the graph...
>> >> > ERROR: GngFlatten error
input=railroads
>> >> > output=railroads_components method=strong
>> >> > Building graph...
>> >> > Registering arcs...
>> >> > 100%
>> >> > Does the network need any special treatment?
>> >> I can not reproduce these errors. Please update your local copy:
>> >> make distclean
>> >> svn --no-ignore status
>> >> svn up
>> >> configure
>> >> make
>> >> Markus M
>> >> > Markus
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171027/52aaf6d2/attachment.html>
