[GRASS-user] Unusual [Open|ESRI]FileGDB: how to import
Markus Metz markus.metz.giswork at gmail.com
Mon Oct 30 13:47:11 PDT 2017
On Mon, Oct 30, 2017 at 4:35 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Fri, 27 Oct 2017, Markus Metz wrote:
>> Instead of manually creating a proj.4 definition, you can use
>> v.in.ogr in=BullTrout_201201_v931.gdb location=bulltrout_location -i
>> to create a location from that gdb. If you don't use the -i flag, the
data
>> will also be imported into the new location.
>> With GRASS 7.3, v.in.ogr will report back if there are any problems with
>> the included SRS, or if no SRS is available for the selected layer.
> Markus,
>   I'm importing all species into their own locations; will combine later.
> The above command worked (so far) with four species, but on one it threw a
> seqfault:
> GRASS 7.3.svn (Fish):~/data/grassdata > v.in.ogr
in=~/data/species/fish/RedbandTrout_201201_v931.gdb/
location=redband_trout_loc
> WARNING: Updating spatial reference with embedded proj4 definition
> WARNING: Datum <unknown> not recognised by GRASS and no parameters found
> Segmentation fault
Rich,
I have fixed the segmentation fault in trunk r71613. Please update your
local copy and test.
Markus M
>   I tried to find the proj4 defintion but have no idea in which file it is
> found. I can provide the directory if desired; it's 18M so I could put it
on
> Dropbox. Or, is there something I can do here to clear the blockage?
> Regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171030/f325f027/attachment.html>
