[GRASS-user] Unusual [Open|ESRI]FileGDB: how to import
Rich Shepard
rshepard at appl-ecosys.com
Mon Oct 30 15:17:52 PDT 2017
On Mon, 30 Oct 2017, Markus Metz wrote:
> Thanks for testing GRASS 7.3!
Markus,
Glad to do it.
> The projection information is problematic because it is contradicting
> itself. WKT says datum and ellipsoid are WGS84, but the embedded proj.4
> string says there is no datum and the ellipsoid is a sphere because of
> "+a=6378137 +b=6378137".
I wondered about this but I'm not sufficiently focused on these details to
have such contradictions immediately visible.
> You should check the geolocation accuracy after reprojection.
Will do this.
Best regards,
Rich
