[GRASS-user] g.extension and SSL
Ken Mankoff
mankoff at gmail.com
Tue Oct 31 14:16:54 PDT 2017
In case anyone else runs across this issue (SSL and g.extension), I've sort-of solved it for now. These are the steps I had to take to get an extension installed on Mac OS X and GRASS 7.2.0 installed via fink. I recall a year ago g.extension worked rather easily with a Homebrew installation.
If I download the ZIP file and try to install the extension that way:
g.extension -s extension=r.stream.order url=/path/to/r.stream.order-71621.zip
I'm told:
ERROR: You don't have permission to install extension to
</sw/Applications/GRASS-mac-7.2.app/Contents/MacOS>. Try to run
g.extension with administrator rights (su or sudo).
Adding sudo before ~g.extension~ does not work.
I made it farther by creating a new GRASS location as sudo:
sudo grass72 -c EPSG:3413 ./Gtmp
But g.extension build fails with:
In file included from io.c:1:
./io.h:8:10: fatal error: 'grass/glocale.h' file not found
#include <grass/glocale.h>
>From the full error message some work was being done in "/sw/src/fink.build/grass72-mac-7.2.0-1/grass-7.2.0/Applications". I looked there and found a sort-of empty shell of the GRASS.app. I fixed it with:
cd /sw/src/fink.build/grass72-mac-7.2.0-1/grass-7.2.0/Applications
sudo mv GRASS-mac-7.2.app/ GRASS-mac-7.2.app.no
sudo ln -s /sw/Applications/GRASS-mac-7.2.app
Then
reports
Installation of <r.stream.order> successfully finished
But ~g.extension -a~ reports: "No extension (module) installed"
Still, ~r.stream.order --help~ does print something, and it appears that the module does run.
I hope this is helpful for someone else, but I doubt it will be due to the limited Google results for these topics. Perhaps the someone else it helps is a future me.
-k.
