[GRASS-user] No Data everywhere when I extract the shadow from a DEM using r.sunmask
Hakim Benoudjit h.benoudjit at gmail.com
Mon Sep 4 08:59:34 PDT 2017
Thanks guys for the quick response.
You were right, the shadow wasn't detected because the region hasn't been
set.
Now it seems to be working, but I'm wondering between `r.sunmask` and
`r.sun` which one should be used to calculate the shadow mask?
Thanks.
Hakim.
On 4 September 2017 at 15:43, Micha Silver <tsvibar at gmail.com> wrote:
> On 09/04/2017 05:15 PM, Hakim Benoudjit wrote:
> Hello,
> First of all, I'm new to this mailinglist and to GrassGIS in general.
> Welcome
> So, I'm trying to use the `r.sunmask` command in order to extract the
> shadow from an `SRTM DEM` of the Alps mountains (Switzerland).
> The image had to be first `reprojected` when I've imported it to a
> `EPSG:21781` location, in order to get both the (lat, lon) in meters
> (similarly to the elevation).
> Here is the command I'm executing (note that the time of the day was
> chosen at 09:00 in the morning to maximize the shadow):
> r.sunmask elevation=n46_e006_1arc_v3 at PERMANENT output=alps-sunmask.tif year=2014 month=9 day=23 hour=9 minute=0 timezone=1
> The problem I have is that the image produced is emtpy (no-data
> everywhere).
> Is there a parameter I'm forgetting to add to the `r.sunmask` command?
> Or should I use `r.sun` command instead, even though I'm not sure about
> the parameters I should provide to it either ?
> Most likely you need to set the region to your DEM.
> g.region -p rast=n46_e006_1arc_v3 at PERMANENT
> FAQ #1 when using GRASS: Always set the region first
> Hakim.
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170904/26bfed71/attachment-0001.html>
