[GRASS-user] Problems using qgis and grass in one python script
balotti.and at gmail.com
Fri Sep 15 00:16:01 PDT 2017
I am not an expert of using GRASS from QGIS, so I don't know if there
are mistakes in the first part where you call GRASS, but for what I can
see could be a problem of empty output filename IMHO.
Il 13/09/2017 13:11, T K ha scritto:
> all = ""
> grass.script.run_command('v.import', input='/home/student/qgis/all.shp',
> output=all)
Try to assign something to 'all' variable, for example:
all="test-out"
Otherwise you could use a little bit hardcoded approach setting directly
the variable 'output' for v.import and the variable 'input' for v.to.rast:
v.import ... output='test-out'
v.to.rast ... input='test-out'
Best Regards,
Andrea Balotti
