[GRASS-user] Problems using qgis and grass in one python script
    Markus Metz
    markus.metz.giswork at gmail.com
    Fri Sep 15 01:01:15 PDT 2017
On Fri, Sep 15, 2017 at 9:42 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 13/09/17 13:11, T K wrote:
>> Hello list,
>> I am very new to the whole GIS topic, so I do not know if this is the
>> right place for my question, but I did not find a more suitable place.
> This is a good place, don't worry.
>> I am trying to combine QGIS and GRASS in one python script.
>> The first step is to import a csv-file and create a shp-layer with QGIS
>> which runs without errors. But when I try to load the shp with grass
>> run_command like v.import or v.in.ogr there is always an error Illegal
>> filename. Character < > are not allowed.
> You already received an answer about possible cause from Andrea.
> However, this seems to be an awful lot of hoops to jump through for the
task at hand. Why not just import your csv file directly into GRASS GIS
with v.in.ascii ?
The last command is v.to.rast, therefore g.region + r.in.xyz with the csv
file as input should do the job.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170915/686fd60d/attachment.html>
