[GRASS-user] Recovering from a build error
Rich Shepard
rshepard at appl-ecosys.com
Sun Sep 17 14:17:16 PDT 2017
On Sun, 17 Sep 2017, Markus Neteler wrote:
>> Errors in:
>> /home/rshepard/gis/grass/grass7_trunk/scripts/d.rast.edit
>> In case of errors please change into the directory with error and run
>> 'make'.
Markus,
Just did this and found the reason for the error:
Fatal Error: Mismatch between the program and library build versions detected.
The library used 3.0 (wchar_t,compiler with C++ ABI 1009,wx containers,compatible with 2.8),
and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1002,wx containers,compatible with 2.8).
../../include/Make/Html.make:14: recipe for target 'd.rast.edit.tmp.html' failed
make: *** [d.rast.edit.tmp.html] Error 1
rm d.rast.edit.tmp.html
I've been using wxPython-3.0.2.0 to build grass 7.3.svn for quite a while
now and ~/.bash_profile tells grass that's what's available:
export GRASS_WXVERSION=3.0.2.0
Can grass be adjusted to use 3.0 as well as 2.8?
Thanks,
Rich
