[GRASS-user] unable to execute d.mon
Javier Álvarez Rodríguez Javier.Alvarez at cedex.es
Mon Sep 18 08:43:21 PDT 2017
Yes, I guess, I've started grass using --text option because I'm interested in using my own "sh". But always find problems to execute d.mon start=wx1
Something to add from my last email. I've also installed QGIS and its GRASS toolbox. Then d.mon works using the QGIS console, I mean from the GRASS toolbox in QGIS...
Thanks
Coordinador de Programa Técnico Científico
Javier.alvarez at cedex.es
Centro de Estudios Hidrográficos
Paseo Bajo de la Virgen del Puerto, 3. 28005 Madrid
Tel.: (+34) 91 335 79 38
-----Mensaje original-----
De: Anna Petrášová [mailto:kratochanna at gmail.com]
Enviado el: lunes, 18 de septiembre de 2017 17:34
Para: Javier Álvarez Rodríguez
CC: grass-user at lists.osgeo.org
Asunto: Re: [GRASS-user] unable to execute d.mon
Have you started GRASS at all? You can normally run these commands only from a running GRASS session.
Anna
On Mon, Sep 18, 2017 at 9:41 AM, Javier Álvarez Rodríguez <Javier.Alvarez at cedex.es> wrote:
> Dear people,
> I wonder why I can’t execute d.mon in my grass72. I’m working on
> fedora 26 (and GNOME) and tried to install grass72. I have installed
> the source code and previously installed the whole set of libraries
> you required, but I can’t open monitors. When typing d.mon or even
> g.gui, I receive the following message, “Unable to execute the
> command”. Do you have any idea to make it work?
> Thanks in advance
> ________________________________
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
