[GRASS-user] unable to execute d.mon
Javier Álvarez Rodríguez
Javier.Alvarez at cedex.es
Tue Sep 19 04:14:11 PDT 2017
Then, installed and checked 7.2.2. Is there anything else you would suggest to check?
Thanks a lot for your time
On Tue, Sep 19, 2017 at 11:48 AM, Javier Álvarez Rodríguez <Javier.Alvarez at cedex.es> wrote:
> Yes, running GRASS is GRASS GIS 7.2.2RC2
There is meanwhile 7.2.2 (final). To refresh your local dnf metadata, try
sudo su
dnf clean metadata && dnf update
Then 7.2.2 should be installed.
Markus
