[GRASS-user] OpenFileGDB input error
Markus Metz markus.metz.giswork at gmail.com
Mon Sep 25 01:15:16 PDT 2017
On Sun, Sep 24, 2017 at 10:18 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Sun, 24 Sep 2017, Rich Shepard wrote:
>>  Using the GUI I ran v.in.ogr, specifying the directory in which the file
>> is found (the location uses the final EPSG reported when 'ogrinfo -al
-so'
>> was run with output directed to a file), the format, and clicked the
single
>> layer in the Input tab. This is the displayed error message:
>> (Sun Sep 24 11:59:03 2017) v.in.ogr
input=/home/rshepard/data/grassdata/wash-state-data/farmland/2016WSDACropDistribution.gdb
layer=WSDACrop_2016
>> Check if OGR layer <WSDACrop_2016> contains polygons...
>> Importing 198132 features
>> Importing 198132 features (OGR layer <WSDACrop_2016>)...
>> ERROR: Unknown geometry type
>> (Sun Sep 24 11:59:59 2017) Command finished (55 sec)
>   More information I should have included. From the ogrinfo metadata:
> Layer name: WSDACrop_2016
> Geometry: Multi Polygon
> Feature Count: 198132
>   What does GRASS call 'Multi Polygon'?
Each polygon of a multi-polygon is imported separately, later on polygons
are converted to GRASS areas.
Regarding the error message, GRASS recognizes the OGR geometry types point,
linestring, polygon, geometry collection, multi-point, multi-linestring,
multi-polygon. Other OGR geometry types like curves and surfaces are not
supported.
Markus M
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170925/71d3ba91/attachment.html>
