[GRASS-user] Extract subnet from grass vector network based on selected nodes
Moritz Lennert
mlennert at club.worldonline.be
Wed Sep 27 14:55:43 PDT 2017
On 27/09/17 21:03, Markus Metz wrote:
> On Wed, Sep 27, 2017 at 4:07 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> > Le 27 septembre 2017 13:11:54 GMT+02:00, Johannes Radinger
> <johannesradinger at gmail.com <mailto:johannesradinger at gmail.com>> a écrit :
> > >Hi,
> > >I have a GRASS vector network that represents a river network (with
> > >many
> > >first order tributaries) and that has additional connected nodes that
> > >represent sampling sites.
> > >I'd like to extract a minimum subnetwork of the full network that still
> > >connects a set of selected nodes (e.g. identified by their cat).
> > >However,
> > >network edges (i.e. river segments) that are not necessary to connect
> > >the
> > >sampling points should be excluded in the new subnetwork. Is there a
> > >function or process in GRASS GIS to extract such a subnetwork that
> > >fully
> > >connects a set of selected nodes?
> > not sure but maybe v.net.spanningtree ?
> v.net.spanningtree calculates a tree covering all nodes in the network,
> not only selected nodes, therefore v.net.spanningtree does not apply here.
If you connect only the selected nodes to the network, wouldn't that
work ? Or does v.net.spanningtree consider all connections between lines
as nodes ?
Moritz
