[GRASS-user] Date import: setting projection units
Markus Metz
markus.metz.giswork at gmail.com
Thu Sep 28 06:46:11 PDT 2017
On Thu, Sep 28, 2017 at 3:38 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Rich Shepard wrote
> > On Wed, 27 Sep 2017, Helmut Kudrnovsky wrote:
> >> Another possibility is to let GRASS define the correct location
> >> parameters
> >> by the dataset itself.
> > Helmut,
> > I would prefer this but was not sure which coordinate-setting option
> > supports this for an OpenFileGDB directory.
> it seems that OpenFileGDB directory isn't recognized. you could file an
> enhancement ticket for this.
> a quick workaround with ogrinfo and grep. :-)
> tested with an example fgdb downloaded somewhere from the net.
> check the layers in the fgdb:
> ogrinfo RH_SampleData.gdb
> INFO: Open of `RH_SampleData.gdb'
> using driver `FileGDB' successful.
> 1: Route (None)
> 2: Centerline_Sequence (None)
> 3: AADT (None)
> 4: Access_Control (None)
> 5: Base_Thickness (None)
> 6: Crashes (None)
> 7: F_System (None)
> 8: Speed_Limit (None)
> 9: Redline__ATTACH (None)
> 10: Centerline (3D Multi Line String)
> 11: Calibration_Point (3D Measured Point)
> 12: Redline (Multi Line String)
> 13: LRSN_MilePoint (3D Measured Multi Line String)
> 14: LRSE_Access_Control (3D Measured Multi Line String)
> 15: LRSE_Crashes (3D Measured Point)
> 16: LRSE_Speed_Limit (3D Measured Multi Line String)
> 17: LRSE_Functional_Class (3D Measured Multi Line String)
> 18: LRSI_MilePoint_Intersections (Point)
> 19: LRSN_RefMarker (3D Measured Multi Line String)
> 20: LRSE_Base_Thickness (3D Measured Multi Line String)
> 21: LRSE_AADT (3D Measured Multi Line String)
> check the srs from one of the layers:
> ogrinfo RH_SampleData.gdb LRSE_Crashes -al -so
> Layer name: LRSE_Crashes
> Geometry: 3D Measured Point
> Feature Count: 14646
> Extent: (215341.513300, 4712138.869500) - (360295.772500, 4806029.751300)
> Layer SRS WKT:
> PROJCS["NAD83 / UTM zone 18N",
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6269"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4269"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-75],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","26918"]]
> FID Column = OBJECTID
> Geometry Column = SHAPE
> ROUTEID: String (12.0)
> MEASURE: Real (0.0)
> DISTANCE: Real (0.0)
> CASE_NUMBER: String (255.0)
> CASE_YEAR: Real (0.0)
> REFERENCE_MARKER: String (12.0)
> ACCIDENT_DATE: DateTime (0.0)
> ROAD_SYSTEM: String (2.0) DEFAULT 'ab'
> NUMBER_FATALITIES: Real (0.0)
> NUMBER_INJURIES: Real (0.0)
> REPORTABLE: String (1.0)
> POLICE_DEPARTMENT: String (5.0)
> INTERSECTION_NUMBER: String (2.0)
> MUNICIPALITY: String (2.0)
> NUMBER_VEHICLES: Real (0.0)
> ACCIDENT_TYPE: String (2.0)
> LOCATION: String (1.0)
> TRAFFIC_CONTROL: String (2.0)
> LIGHT_CONDITION: String (1.0)
> WEATHER: String (1.0)
> ROAD_CHARACTER: String (1.0)
> ROAD_SURFACE_CONDITION: String (1.0)
> COLLISION_TYPE: String (2.0)
> PEDESTRIAN_LOCATION: String (1.0)
> PEDESTRIAN_ACTION: String (2.0)
> EXTENT_OF_INJURIES: String (5.0)
> REGION_COUNTY: String (2.0)
> LOW_NODE: String (5.0)
> HIGH_NODE: String (5.0)
> ACCIDENT_TIME: DateTime (0.0)
> REPORTING_AGENCY: String (100.0)
> OFFICER_BUILDING_NUMBER: String (5.0)
> DMV_ACCIDENT_CLASSIFICATION: String (1.0)
> LOCATION_ERROR_CODE: String (3.0)
> COMM_VEH_ACC_IND: String (1.0)
> HIGHWAY_IND: String (1.0)
> INTERSECTION_IND: String (1.0)
> UTM_NORTHING: Real (0.0)
> UTM_EASTING: Real (0.0)
> REL_ACC_VEH: String (50.0)
> CRASH_SEVERITY: Real (0.0)
> FROMDATE: DateTime (0.0)
> TODATE: DateTime (0.0)
> TEST_DOMAIN: Integer(Int16) (0.0)
> EVENT_ID: String (50.0)
> LocError: String (100.0)
> grep the srs info into a text file
> ogrinfo RH_SampleData.gdb LRSE_Crashes -al -so | grep -A22 -B0 PROJCS >
> my.prj
> and in the GRASS start up wizard choose:
> Read projection and datum terms from a Well Known Text (WKT).prj file.
> all done.
Shorter version:
v.in.ogr input=RH_SampleData.gdb layer=LRSE_Crashes output=LRSE_Crashes
location=name_of_new_location
Markus M
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170928/d2483a1f/attachment.html>
