[GRASS-user] OpenFileGDB input error
Markus Metz markus.metz.giswork at gmail.com
Thu Sep 28 10:40:17 PDT 2017
On Wed, Sep 27, 2017 at 11:15 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > > You can force a curve geometry to its linearized version (curves are
> > approximated with segments) with:
> > > hGeom = OGR_G_ForceTo(hGeom,
> > OGR_GT_GetLinear(OGR_G_GetGeometryType(hGeom)))
> > Thanks for the hint!
> > I'm looking for a way to support non-linear geometries in v.in.ogr. Is
> > there any advantage of using OGR_G_ForceTo() instead of
> > OGR_G_GetLinearGeometry()?
> Ah, I just forgot the existence of OGR_G_GetLinearGeometry(). Might be
indeed more obvious to use. Both use ultimately the same mechanisms for
linear approximation.
> The main difference being that OGR_G_GetLinearGeometry() returns a new
object, whereas OGR_G_ForceTo() transforms in place.
As of trunk r71513, v.in.ogr converts any curve types to linear equivalents
with OGR_G_GetLinearGeometry().
Thanks for the feedback, Even!
Markus M
> Evven
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170928/bd87fe7a/attachment.html>
