[GRASS-user] Lack of memory importing .shp file
Rich Shepard rshepard at appl-ecosys.com
Thu Sep 28 15:05:36 PDT 2017
On Thu, 28 Sep 2017, Markus Metz wrote:
> The update interval of top might be too long to show the amount of memory
> consumed in the last split seconds.
Markus,
   True.
> I suggest to use v.in.ogr instead of v.import because v.import snaps by
> default which consumes a lot of memory and takes a long time.
   Will do.
> If v.in.ogr suggests snapping, you can set the environment variable
> GRASS_VECTOR_LOWMEM=1 to reduce memory consumption. This will slow down
> the import because temporary data will be kept on disk instead of in
> memory.
   The time doesn't matter because I have other things to do while v.in.ogr
is chewing on the file.
Many thanks,
Rich
