[GRASS-user] Change the length and type of columns in an attribute table
Camille Bezzina
camille.bezzina at geophom.fr
Thu Apr 5 06:30:09 PDT 2018
Ok thanks Markus for your answer.
But I have another question :
I have 2 differents vectors with the same attribute table structure.
This problem is just for one of them.
For the first vector the attribute table is like that :
> name type length
> cat integer 20
> ID character 24
> PREC_PLANI double precision 20
> NATURE character 31
> HAUTEUR integer 20
> id_2 integer 20
and for the second :
> name type length
> cat integer 20
> ID text 1000
> NATURE text 1000
> HAUTEUR integer 20
> id_2 integer 20
So when I want to patch my 2 vectors with v.patch, there is the
following message :
(Thu Apr 5 15:01:50 2018)
v.patch -e --overwrite --verbose
input=zone_vegetation_D90_decoupe at AIP_RONCHAMP_MNE,zone_vegetation_D70_decoupe at AIP_RONCHAMP_MNE
output=TEST_merge_D70_D90
ERROR: Length of string columns differ
(Thu Apr 5 15:01:51 2018) La commande s'est terminée (1 sec)
Le 05/04/2018 à 14:41, Markus Metz a écrit :
> On Wed, Apr 4, 2018 at 5:54 PM, Camille Bezzina
> <camille.bezzina at geophom.fr <mailto:camille.bezzina at geophom.fr>> wrote:
> > Hello all,
> > I have a problem when I want to modify an attribute table.
> > I add a new vector with v.in.ogr. My attribute table is build like
> that :
> > name type length
> > cat integer 20
> > ID character 24
> > NATURE character 31
> > HAUTEUR integer 20
> > id_2 integer 20
> > I would like to remove the column 'HAUTEUR', but when I remove this
> > column, my two character columns (ID and NATURE) change automatically to
> > become :
> > ID text 1000
> > NATURE text 1000
> > Do you know why the simple fact to remove a column (HAUTEUR) change type
> > and length of other columns.
> The reason is that GRASS uses SQLite as database manager, and in
> SQLite there is nothing like varchar(24), only text without any length
> restrictions. That means, when importing vector data with attributes,
> any text fields are converted to text by SQLite itself. The value 1000
> as length for text is somewhat misleading here because the maximum
> allowed length in SQLite is by default 1 billion.
> Markus M
> > Thanks,
> > Camille BEZZINA
> > Chargé d'études géomatiques et photomontages
> > Geophom
> > 57 rue du Chemin Neuf 44521 OUDON
> > Standard: +33(0)2 85 52 02 59
> > Ligne directe: +33(0)9 72 56 81 71
> > www.geophom.fr <http://www.geophom.fr>
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
Camille BEZZINA
Geophom
www.geophom.fr
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180405/df64bac1/attachment.html>
