[GRASS-user] problem with g.in.ogr
Moritz Lennert mlennert at club.worldonline.be
Thu Apr 12 09:20:15 PDT 2018
On 12/04/18 17:03, Camille Bezzina wrote:
> Hi Markus,
> In the file attached you can find the full output of v.import with verbose.
> I launch this one with v.in.ogr and this is the answer.
At the end you can see:
"Some input polygons are overlapping each other.
If overlapping is not desired, the data need to be cleaned.
The input could be cleaned by snapping vertices to each other.
Estimated range of snapping threshold: [1e-08, 1]
Try to import again, snapping with at least 1e-08: 'snap=1e-08'"
Try importing with snap=0.01 or something like that (depending on the
nature and precision of your data.
Moritz
> Thanks.
> Le 12/04/2018 à 16:39, Markus Metz a écrit :
>> On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina
>> <camille.bezzina at geophom.fr <mailto:camille.bezzina at geophom.fr>> wrote:
>> > Hello all,
>> > I have a problem with v.in.ogr.
>> > I would like to import a shape file (with 57851 polygons) with v.in.ogr.
>> > v.import --verbose
>> input=/media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe.shp
>> layer=bati_D90_decoupe output=bati_D90_decoupe -o
>> > Visibly the order is going well, my attribute table contains 57851
>> attributes but when I check my vector with display, some polygons are
>> missing.
>> Can you post the full output of v.import with --verbose?
>> Considering that you override the projection check with -o, you can
>> also use v.in.ogr directly and then post the full output of v.in.ogr
>> -o --verbose.
>> Markus M
>> > Thanks for your help.
>> > Camille Bezzina
>> > Geophom
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
> Camille BEZZINA
> Chargé d'études géomatiques et photomontages
> Geophom
> 57 rue du Chemin Neuf 44521 OUDON
> Standard: +33(0)2 85 52 02 59
> Ligne directe: +33(0)9 72 56 81 71
> www.geophom.fr
