[GRASS-user] g.region on different mapsets of the same location
Nikos Alexandris nik at nikosalexandris.net
Mon Apr 16 07:11:57 PDT 2018
* Bernardo Santos <bernardo_brandaum at yahoo.com.br> [2018-04-16 13:32:49 +0000]:
>Dear all,
>I am running some GIS procedures in a series of maps present in the same location. To speed up the process, I opened different GRASS GIS sections in the same location, but in different mapsets, and then, in each section/mapset I ran:
>r.in.gdal input input_map_of_this_mapset.tif output=input_map_of_this_mapsetg.region map=input_map_of_this_mapset... (a series of procedures)
>Do you think I'll have problems in this process?Does g.region in a given mapset affects the region in other mapsets?(I should also use a temporary region, but I am also not sure if these temporary region files are set for the whole location or are limited to the current mapset).
>Or should I do that in different locations?
>Thanks a lot!Bernardo Niebuhr
Each Mapset has his own definition of the computational region, which is
the file named `WIND`. You shouldn't have any problems, even running
processes in different Mapsets in parallel.
Good luck, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180416/3bb5731a/attachment.sig>
