[GRASS-user] r.horizon and negative tilt
Mark Lake
mark.lake at ucl.ac.uk
Fri Aug 3 10:05:22 PDT 2018
Frank,
Some years ago I wrote a module (also called r.horizon) which I
think does what you want. I never got around to formally
contributing it (must compare with the existing r.horizon and do
so some time). Anyhow, have updated for GRASS 7 and will send you
the code direct - it compiles as r.horizon2 to avoid collision
with the existing module.
Regards,
Mark
Frank David <frank.david at geophom.fr> writes:
> Ho yes, why not. I could use r.viewshed to find the farest part
> of the
> topography able to see my point and get it's angle mode. The
> trick to
> find is how to get that cell ?
> Best regards,
> frank
> Le 30/07/2018 à 11:18, balotti.and at gmail.com a écrit:
>> Il 30/07/2018 09:24, Frank David ha scritto:
>>> Hi Andrea,
>>> Thanks for your message. But what is the ground plane ?
>>> r.horizon use
>>> the topography, so nothing is plane (and the earth curvature
>>> tends to
>>> lower the ground).
>> Yes, what you explain below is what I mean with "ground plane".
>>> I guess as the calculation is done at ground level, the
>>> minimum
>>> viewable horizon cannot be lower than zero. The calculation
>>> should be
>>> done higher than ground level to "see" negatives horizon.
>> Have you taken a look to r.viewshed? I never tried it but maybe
>> is
>> useful for your purposes.
>>> Never mind I will try to create my own r.horizon with
>>> r.transect or
>>> r.profile.
>>> Best regards,
>>> Frank
>> Best regards,
>> Andrea
>>> Le 30/07/2018 à 08:47, balotti.and at gmail.com a écrit:
>>>> Hi Frank,
>>>> just my opinion but r.horizon I suppose is targeted to solar
>>>> radiation modules and because of that returns only the
>>>> line-of-sight
>>>> "obstacles" above the ground plane, where direct sunlight may
>>>> be
>>>> obstructed by obstacles.
>>>> best regards,
>>>> Andrea Balotti
>>>> Il 28/07/2018 15:59, Frank David ha scritto:
>>>>> Dear all,
>>>>> It seems that r.horizon in does not return negative
>>>>> heights. How
>>>>> it's possible in case of the given point from the
>>>>> calculation is
>>>>> done is located on mountain and the horizon around is below
>>>>> zero
>>>>> ??. I miss something may be...
>>>>> Thank you for your explanations
>>>>> Regards
>>>>> Frank
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Dr Mark Lake
Senior Lecturer in Archaeology
UCL Institute of Archaeology
31-34 Gordon Square
London WC1H 0PY
UK
Tel: +44 (0)207 679 7495
Fax: +44 (0)207 383 2572
