[GRASS-user] r.horizon and negative tilt
    Markus Metz
    markus.metz.giswork at gmail.com
    Sat Aug  4 02:18:18 PDT 2018
On Mon, Jul 30, 2018 at 4:55 PM, Frank David <frank.david at geophom.fr> wrote:
> Hello Markus,
> is it possible to add an option to evaluate the negatives hight in a
future release ? (I don't know C)
Please try trunk r73049. Negative angles are now allowed by default.
Markus M
> Best regards,
> Frank
> Le 30/07/2018 à 16:19, Markus Metz a écrit :
> On Sat, Jul 28, 2018 at 3:59 PM, Frank David <frank.david at geophom.fr>
wrote:
> > Dear all,
> > It seems that r.horizon in does not return negative heights. How it's
possible in case of the given point from the calculation is done is located
on mountain and the horizon around is below zero ??. I miss something may
be...
> r.horizon is indeed ignoring points that are lower than the given point,
see
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.horizon/main.c#L1037
> and following lines
> I agree that this behaviour is questionable
> Markus M
> > Thank you for your explanations
> > Regards
> > Frank
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180804/46a6dfeb/attachment.html>
