[GRASS-user] conversion to fire simulation data set in the Grass GIS
Thomas Adams
tea3rd at gmail.com
Sat Aug 4 17:04:29 PDT 2018
Kalindu,
I do not see any lat/long coordinates. Do you have them in a separate file
by station ID. As Rich Shepard suggested, it is far best to have all the
data in a single file including the lat/long locations for the station IDs.
Tom
On Sat, Aug 4, 2018 at 12:58 PM, Kalindu Perera <kkc199408 at gmail.com> wrote:
> Hi Thomas,
> Yes, the starting point is latitude and longitude coordinates.
> It's actually not 2 columns. It has a separate column for each one slope.
> elevation etc... The data for each wildfire is presented in rows.
> I'll attach a dataset which has the data about the wildfire spread and
> starting point and a weather dataset another file. we are currently in a
> stage of combining those 2 and creating one file which shows the wildfire
> starting point spread and weather data both on one file.
> The inputs to the wildfire model in grass GIS use data as separate files.
> we need to convert our sheet to that type of set of separate data files.
> You can download the Grass GIS fire simulation dataset clicking here
> <https://grass.osgeo.org/download/sample-data/> and go to the end of that
> page.
> It has the data as a set of files, when extracted go to
> demolocation->demomapset->cats
> Thank you ...!!!!!!!!
> On Sat, 4 Aug 2018 at 19:47, Thomas Adams <tea3rd at gmail.com> wrote:
>> Kalindu,
>> First, I have never done any wildfire modeling and I am not familiar with
>> the process in GRASS. So, I'm not sure what the requirements are in GRASS
>> to do this. However, I do not understand how 2 columns of data can contain
>> "starting point of the fire, slope, wind velocity, wind direction,
>> elevation, fuel models and fuel moisture" unless the data are in separate
>> rows; but that does not make sense either to me. Is the "starting point of
>> the fire" in lat/long coordinates or some other geographic coordinates?
>> I really think it would be helpful to see an example dataset with an
>> explanation. I or others can help you with answering questions about
>> importing your datasets, but not without this information.
>> Best,
>> Tom
>> On Sat, Aug 4, 2018 at 10:01 AM, Kalindu Perera <kkc199408 at gmail.com>
>> wrote:
>>> Hi Thomas,
>>> Thanks a lot for your reply. I'll explain more.
>>> We have a dataset with data about a wildfire, starting point of the
>>> fire, slope, wind velocity, wind direction, elevation, fuel models and fuel
>>> moisture.
>>> That data is in an excel sheet separated into columns.
>>> we need to convert that data to the format which is like in the Grass
>>> GIS fire simulation data set. So that we can calculate the spread of our
>>> wildfire using r.ros
>>> Grass GIS fire simulation data set has data about 1 wildfire and the
>>> data is presented separately as files. As an example slope is a separate
>>> file. the elevation is another file
>>> What we need is how to convert our wildfire data which is in the excel
>>> sheet to those type of files?
>>> Is there any script or something to convert?
>>> Thank you..!!!!!!
>>> On Sat, 4 Aug 2018 at 18:36, Thomas Adams <tea3rd at gmail.com> wrote:
>>>> Kalindu,
>>>> I think you need to provide more information. It sounds like you have
>>>> point data, which means your data should be imported using v.in.ogr or
>>>> v.in.ascii, if you were to convert you excel file to an ascii text file.
>>>> Regards,
>>>> Tom
>>>> On Sat, Aug 4, 2018 at 3:46 AM, Kalindu Perera <kkc199408 at gmail.com>
>>>> wrote:
>>>>> Hi everyone,
>>>>> We have encountered a problem when we trying to convert a wildfire
>>>>> data set to the format that can be used in the grass GIS. We have the data
>>>>> in an excel sheet as records. Grass GIS fire simulation dataset has a set
>>>>> of files as the inputs. The format of the data in the files is unclear. Is
>>>>> there any conversion method of normal fire data to the format that can be
>>>>> used in the Grass GIS?...We have the same input data, we need to convert
>>>>> them like the fire simulation data set provided in the Grass GIS sample
>>>>> data page.
>>>>> Thank you...!!!!!!!
>>>>> Awaiting a helpful response
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180804/d2127667/attachment.html>
