[GRASS-user] g.gui.psmap: set region
Anna Petrášová
kratochanna at gmail.com
Tue Aug 14 18:04:05 PDT 2018
On Tue, Aug 14, 2018 at 6:50 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> It appears that the only maps available for setting a ps.map region in
> the
> cartographic composer are those of the current mapset. When looking at the
> choices, no other mapset can be opened to view the contained maps. Is this
> correct?
no, you should be able to add maps from any accessible mapset, use
g.mapsets -s to check your mapsets are accessible.
> If so, I'll be sure to change the current mapset to the one with the
> region I want to use for the cartographic layout.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180814/50f75858/attachment.html>
