[GRASS-user] g.gui.psmap: set region
Anna Petrášová kratochanna at gmail.com
Tue Aug 14 18:41:20 PDT 2018
On Tue, Aug 14, 2018 at 9:36 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Tue, 14 Aug 2018, Anna Petrášová wrote:
> > no, you should be able to add maps from any accessible mapset, use
> > g.mapsets -s to check your mapsets are accessible.
> Anna,
>    In the ps.map manual I read setting the region using g.mapsets, but
> within
> the cartographic composer the region setting dropdown choice box did not
> let
> me select a map in a different mapset.
It works for me, are we talking about "Map frame settings"?
> Using g.mapsets -s is still on the
> command line, not within the GUI as far as I can tell.
not sure what you mean, g.mapsets -s sets the visibility of mapsets globally
> Best regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180814/4ae33704/attachment.html>
