[GRASS-user] Georeferencing a vector onto a WMS layer
Jacki Pilon
jacki.pilon at gmail.com
Sun Aug 19 15:08:34 PDT 2018
Well, I start with a CSV file containing records of numbered things
(houses, parcells...) having a noun (a proper noun) and X, Y coordinates
values. These names and locations have been recorded from an old paper map
(X and Y are in millimeters). The geographic coverage of the map is small
(around 2 x 3 km, printed onto a 210 x 300 mm page).
The map shows hundreds of things worth being recorded.
I would like to georeference this set of "things" in order to display them
in position, overlaid on a general map.
A few of them (for example chapels, churches, crossroads...) can be
relatively easily located on modern, georeferenced, maps and hence, be used
as ground control points.
I first build a vector layer in importing this ascii file in QGIS, and I
could see a correct result, points at relative good positions and labels
with the nouns.
But now, I have troubles in using the QGIS georeferencer, as it seems to
accept only rasters (not vectors) and these rasters are supposed to be
files from the computer. I would prefer to use a VMS multilayer map that
would allow to take benefit of more than one single layer in the process
of defining the ground control points.
Thanks for your attention and for your help.
Jacki
Le dim. 19 août 2018 à 11:31, Moritz Lennert <mlennert at club.worldonline.be>
a écrit :
> [Please keep discussions on the list.]
> Am 18. August 2018 20:59:03 MESZ schrieb Jacki Pilon <
> jacki.pilon at gmail.com>:
> >Thank you Moritz. Unfortunately I cannot go further since I have bad
> >responses from the OSM servers like :
> >https://osm.geobretagne.fr/gwc01/service=wms
> You will have to be much more precise about what exactly you do and what
> exactly are the messages you receive.
> Otherwise it will be difficult for anyone to help you.
> Moritz
> >Yours,
> >Jacki
> >Le ven. 17 août 2018 à 13:01, Moritz Lennert
> >a écrit :
> >> On 17/08/18 07:58, Jacki Pilon wrote:
> >> > Bonjour,
> >> > I coudn't find a way to georeference a vector (with arbitrary X Y
> >> > coordinates) by using either a WMS or a raster layer. Any advice ?
> >> https://grass.osgeo.org/grass74/manuals/g.gui.gcp.html
> >> It allows you to georeference a vector. If you want to use a WMS as
> >> background you probably have to import it first using r.in.wms.
> >> Moritz
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180820/9a78e8fd/attachment.html>
