[GRASS-user] Problem with v.to.db after v.dissolve and v.category
Markus Metz
markus.metz.giswork at gmail.com
Mon Aug 20 13:27:14 PDT 2018
On Mon, Aug 20, 2018 at 4:11 PM, Mira Kattwinkel <
kattwinkel-mira at uni-landau.de> wrote:
> Dear list,
> I dissolve a vector map of lakes based on the names of the features
(v.dissolve). As many of the features do not have names, I get, among the
others, one new feature built up by many parts.
> v.dissolve input=lakes at PERMANENT column=name output=lakes_diss
> I do get a warning during the dissolve:
> WARNING: Number of centroids exceeds number of areas: 44345 > 43502
> WARNING: Number of duplicate centroids: 1237
> This results in 932 features with one containing the majority of lakes
(those without a name). Then, I want to calculate the area (v.to.db) but
this gives a wrong result because I need the area of every single lake.
> This is the same problem as described here
https://lists.osgeo.org/pipermail/grass-user/2011-January/059282.html and I
followed the advice given by Markus. However, I still get one big feature
without a name and get error messages when calculating the area. Can
anybody please give me an hint what's going wrong?
> Here are the steps:
> 1. delete categories:
> v.category input=lakes_diss at PERMANENT output=lakes_diss_wocat option=del
cat=-1
> Processing features...
> Copying attribute table(s)...
> Building topology for vector map <lakes_diss_wocat at PERMANENT>...
> Registering primitives...
> 88399 primitives registered
> 1409269 vertices registered
> Building areas...
> 43502 areas built
> 43426 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 45215
> Number of primitives: 88399
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 45291
> Number of centroids: 43108
> Number of areas: 43502
> Number of isles: 43426
> v.category complete. 43108 features modified.
> (Mon Aug 20 15:59:30 2018) Command finished (3 sec)
> --> still 932 features in attribute table
v.category deletes categories from geometries, but does not touch the
attribute table. Since you deleted all categories in layer 1, you should
also delete the attribute table linked to layer 1 with
v.db.droptable map=lakes_diss_wocat layer=1 -f
> 2. add category
> v.category input=lakes_diss_wocat at PERMANENT output=lakes_diss_wcat
option=add
you should specify the geometry type for which categories should be added,
here type=centroid
Alternatively, you could use with GRASS 7.5
v.extract input=lakes dissolve_column=name type=area output=lakes_diss
Markus M
> Building topology for vector map <lakes_diss_wcat at PERMANENT>...
> Building areas...
> 43502 areas built
> 43426 isles built
> Number of points: 0
> Number of lines: 0
> (Mon Aug 20 16:02:07 2018) Command finished (3 sec)
> --> 932 features in attribute table
> 3. add new column and populate with area
> v.db.addcolumn map=lakes_diss_wcat at PERMANENT columns=area double
> v.to.db map=lakes_diss_wcat at PERMANENT option=area columns=area
> Reading areas...
> Updating database...
> WARNING: Record (cat 933) does not exist (not updated)
> [a long long list...]
> 43108 categories read from vector map (layer 1)
> 932 records selected from table (layer 1)
> 932 categories read from vector map exist in selection from table
> 42176 categories read from vector map don't exist in selection from table
> 932 records updated/inserted (layer 1)
> Thanks a lot,
> Mira
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180820/3f151251/attachment.html>
