[GRASS-user] Computing the maximum number of consecutive days on a STRDS
Veronica Andreo veroandreo at gmail.com
Wed Aug 22 07:10:49 PDT 2018
Hello Pierre,
Check this helper script that Thomas Leppelt kindly sent me when I asked a
very similar question ;-) Maybe, you can figure out from there.
In my case, I needed to count consecutive days with temperature lower than
2 degrees within each week, so I created a weekly "mask" to be able to add
1 every time days met the condition.
HTH,
Vero
El mié., 22 ago. 2018 a las 15:29, Pierre Roudier (<pierre.roudier at gmail.com>)
escribió:
> Hi,
> I'm trying to compute the maximum number of consecutive days according
> to a given rule (eg: maximum of consecutive days with precipitation >
> 0 mm) on a STRDS, but I'm getting stuck with the syntax.
> Is that something possible to do within GRASS's temporal framework?
> Kind regards,
> Pierre
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180822/448be10c/attachment-0001.html>
Type: application/x-sh
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180822/448be10c/attachment-0001.sh>
