[GRASS-user] Remove points from boundary
Rich Shepard rshepard at appl-ecosys.com
Fri Aug 24 05:31:39 PDT 2018
On Fri, 24 Aug 2018, Micha Silver wrote:
> If your set of points are ordered, you might want to have a look at the
> v.in.lines module. THen, assuming the set of points are indeed a closed
> boundary (the first and last points are equivalent) then v.type will
> convert the line to a boundary.
Micha,
   Yes, the first and last points are the same. I'll look at v.in.lines and
v.type to clean this up.
Toda,
Rich
