[GRASS-user] Display times with ps.map products
Rich Shepard rshepard at appl-ecosys.com
Thu Aug 30 11:24:34 PDT 2018
On Thu, 30 Aug 2018, Rich Shepard wrote:
> After 'clipping' the raster per the above series of commands the output
> file, 'dubois_crk_dem' is much smaller at 169,182,790 Bytes, but when
> ps.map is run it reports the output scale set to 1:789624, or almost 10x
> larger. It also takes a _very_ long time to load while the .ps map is
> being created.
   More information: I stopped the ps.map command after 21 minutes trying to
load dubois_crk_dem.
   Where should I start looking for the reason? The *.psmap file? The
creation of the 'clipped' raster? Some place else?
Rich
