[GRASS-user] grass-user Digest, Vol 152, Issue 4
    Helmut Kudrnovsky
    hellik at web.de
    Thu Dec  6 23:16:25 PST 2018
>Opearting system=eindows 8.1
>Grass gis version = 7.4
>Command typed in cmd=
>d.mon wx0
>d.title map=soils color=red size=6 -s
>Then no tiles appear
>Why the module is not working
have you read the manual?
https://grass.osgeo.org/grass74/manuals/d.title.html
d.title generates to standard output a string which can be used by d.text to
draw a TITLE for the raster map layer name in the active display frame on
the graphics monitor. Output created by d.title can be redirected into a
file, or piped directly into d.text to display the map TITLE created by
d.title. The map TITLE created will include the map layer's name, TITLE,
MAPSET, LOCATION_NAME, geographic region boundary coordinates, and cell
resolution. If the -d draw flag is used, then d.title will call d.text for
you and the title will be automatically rendered to the display.
For example, a user wishing to create a suitable TITLE for the Spearfish, SD
soils map layer and to display this TITLE in the active display frame on the
graphics monitor might type the following:
    d.title map=soils color=red size=5 > TITLE.file
    d.text < TITLE.file
Alternately, the user might pipe d.title output directly into d.text:
    d.title map=soils color=red size=5 | d.text
A file created by d.title can be displayed with d.text. Information
contained in this file takes precedence over the color and size parameters
for d.text.
you need to use d.title in connection with d.text, e.g. on the OSGeo4W cmd
line
d.mon start=wx1
d.rast map=elevation
d.title -d map=elevation color=red size=5
or
d.title map=elevation color=red size=5 | d.text
d.mon stop=wx1
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
