[GRASS-user] v.patch eats my large polygons
    Robert Nuske
    rsn.mailinglists at gmail.com
    Tue Dec 18 05:14:37 PST 2018
Dear GRASS-Users,
after an abstinence period I started again to use GRASS 7.4 on Ubuntu
18.04 and am now facing v.patch eating my large polygons.
38 vector maps (polygon) cover separate parts of my study area. A few
share a boundary with their neighbor, most do not. To further work with
all polygons from all sub plots, I want to merge all sub plots into one
vector map. I do NOT need the polygons to get dissolved (disected &
rebuild) at the boundary of two sub plots.
Large (area, number of vertices and number of islands) polygons, which
touch another large polygon at the common border of two sub plots are
not in the patched vector map.
What I did:
v.patch in=gaps_1,gaps_2 out=gaps_merged
What did not help was the -b flag. Lot's of boundaries but no areas anymore.
To illustrate my problem, an image (https://imgur.com/4n3le65) with two
sub plots (left an right) with a common border at the smallest part. All
colored area are polygons. The islands are white. The orange polygons
are the results of v.patch. The light gray and dark gray polygon are
missing in the resulting v.patch-map.
Did anyone experience similar behavior before and know of a cure?
Thanks
   Robert
