[GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
Helmut Kudrnovsky
hellik at web.de
Thu Feb 1 03:04:17 PST 2018
Dinarzarde Raheem wrote
> I have been trying to run the addon r.vif using Grass for MS Windows
> standalone v. 7.2.2 and v. 7.0.5 on three separate PCs (two have Windows 7
> 32bit/64 bit, one runs Windows 10 Home 64 bit). I have been testing the
> r.vif installation using the example on the r.vif page of the Grass 7
> addons manual (i.e. this uses the GRASS 7 Climatic data time series NC
> location nc_climate_spm_2000_2012).
> With v. 7.2.2 (in both Windows 7 and 10) I can load the extension, and can
> visualise Addons in the search modules tab, but the r.vif. tool is not
> visible under Addons.
> With v. 7.0.5 (in both Windows 7 and 10), I can load r. vif, visualise it
> under Addons in the Search Modules tab and run it, but I get the
> following error message:
> (Wed Jan 31 15:06:21 2018)
> r.vif
> maps=2011_01_precip at climate_1970_2012,2011_02_precip at climate_1970_2012,2011_03_precip at climate_1970_2012,2011_04_precip at climate_1970_2012,2011_05_precip at climate_1970_2012,2011_06_precip at climate_1970_2012,2011_07_precip at climate_1970_2012,2011_08_precip at climate_1970_2012,2011_09_precip at climate_1970_2012,2011_10_precip at climate_1970_2012,2011_11_precip at climate_1970_2012,2011_12_precip at climate_1970_2012
> maxvif=10 file=C:\grassworkspace\2011test
> Reading in the data ...
> Traceback (most recent call last):
> File "C:\Users\dinr\AppData\Roaming\GRASS7\addons/scripts/
> r.vif.py", line 365, in
> <module>
> sys.exit(main(*gs.parser()))
> r.vif.py", line 226, in main
> p = ReadData(IPF, n)
> r.vif.py", line 156, in ReadData
> os.remove(tmpcov)
> WindowsError: [Error 32] The process cannot access the file
> because it is being used by another process:
> 'c:\\users\\dinr\\appdata\\local\\temp\\tmpsggohd'
> (Wed Jan 31 15:06:25 2018) Command finished (4 sec)
> Is there anything I can do to fix this issue?
the reason for the error are these lines of code in the r.vif script:
155 # Clean up
156 os.remove(tmpcov)
the temporary file tmpcov isn't closed, therefore the temporary file can't
be deleted.
just for testing I changed locally here in the script
155 # Clean up
156 # os.remove(tmpcov)
now the script finishes with results.
the reason is that handling of temporary files in python is different in
linux and windows.
ping the script author (mentioned in [1]) and ask him to adapt the script
that it's also working in windows.
[1] https://grass.osgeo.org/grass74/manuals/addons/r.vif.html
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
