[GRASS-user] v.generalize failing on some geoms
Paolo Cavallini cavallini at faunalia.it
Fri Feb 9 09:19:13 PST 2018
Hi all,
v.generalize is failing to simplify some of my geometries when in
EPSG:3857. Same geoms in EPSG:3003 were simplified correctly.
Incorrect borders were reported, unclear to me why.
All the best, and thanks for any hint.
Avvio dell'algoritmo v.generalize.simplify - Vector based simplification
generalization....
g.proj -c proj4="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
v.in.ogr min_area=0.0001 snap=-1
input="/tmp/processing63c3c94ab569415fba39f41c12e3e48f"
layer=1518196447.565 output=tmp1518196448046 --overwrite -o
g.region n=5538851.39594 s=5150937.66442 e=1377191.37538 w=1004373.60434
res=100
v.generalize input="tmp1518196448046" method=douglas threshold="1000"
look_ahead="7" reduction="50" -l
output="output081005b4fafd473bbfa438a964de80f1" --overwrite
v.out.ogr -s -e input=output081005b4fafd473bbfa438a964de80f1 type=auto
output="/tmp/processing63c3c94ab569415fba39f41c12e3e48f/3d37e56a7f5f4e17a052af23fcace818"
format=ESRI_Shapefile output_layer=output --overwrite
Sto avviando GRASS GIS...
Executing ...
ATTENZIONE: Updating spatial reference with embedded proj4 definition
ATTENZIONE: Datum non riconosciuto da GRASS e nessun parametro trovato
Default region was updated to the new projection, but if you have
multiple mapsets `g.region -d` should be run in each to update the
region from the default
Informazioni sulla proiezione aggiornate
La verifica della proiezione verrà ignorata
Check if OGR layer contains polygons...
100
Creating attribute table for layer ...
Importing 17 features (OGR layer )...
0..5..11..17..23..29..35..41..47..52..58..64..70..76..82..88..94..100
Registrando primitive...
36 primitives registered
58960 vertices registered
Numero di nodi: 36
Numero di primitive: 36
Numero di punti: 0
Numero di linee: 0
Numero di confini: 36
Numero di centroidi: 0
Numero di aree: -
Numero di isole: -
Cleaning polygons
Si sta rompendo i poligoni...
Breaking polygons (pass 1: select break points)...
2..5..8..11..13..16..19..22..25..27..30..33..36..38..41..44..47..50..52..55..58..61..63..66..69..72..75..77..80..83..86..88..91..94..97..100
Breaking polygons (pass 2: break at selected points)...
Rimozione dei duplicati in corso...
1..3..5..7..9..11..13..15..17..19..21..23..25..27..29..31..33..35..37..39..41..43..45..47..50..52..54..56..58..60..62..64..66..68..70..72..74..76..78..80..82..84..86..88..90..92..94..96..98..100
Breaking boundaries...
0..2..4..6..8..10..12..14..16..18..20..22..24..26..28..30..32..34..36..38..40..42..44..46..48..50..52..54..56..58..60..62..64..66..68..70..72..74..76..78..80..82..84..86..88..90..92..94..96..98..100
1..3..5..7..9..11..13..15..17..19..21..23..25..27..29..31..33..35..37..39..41..43..45..47..49..51..53..55..57..59..61..63..65..67..69..71..73..75..77..79..81..83..85..87..89..91..93..95..97..99..100
Cleaning boundaries at nodes...
Merging boundaries...
2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
Removing dangles...
Costruendo aree...
0..2..4..6..8..10..12..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
14..16..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
18..20..22..24..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
26..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
28..30..32..34..36..38..40..42..44..46..48..ATTENZIONE: Dimensione
512 areas built
24 isles built
Numero di nodi: 3653
Numero di primitive: 7972
Numero di punti: 0
Numero di linee: 0
Numero di confini: 7972
Numero di aree: 512
Numero di isole: 24
ATTENZIONE: Numero di confini non corretti: 8
Removing bridges...
1530 primitives registered
48520 vertices registered
Costruendo aree...
0..2..4..6..8..10..12..14..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
16..18..20..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
22..24..26..28..30..32..34..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
36..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
38..40..42..44..46..48..50..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
52..54..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
56..58..60..62..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
511 areas built
25 isles built
Isole allegate...
4..8..12..16..20..24..28..32..36..40..44..48..52..56..60..64..68..72..76..80..84..88..92..96..100
Numero di nodi: 1038
Numero di primitive: 1530
Numero di punti: 0
Numero di linee: 0
Numero di confini: 1530
Numero di aree: 511
Numero di isole: 25
ATTENZIONE: Vect_get_point_in_poly_isl(): collapsed area
ATTENZIONE: Non è possibile calcolare il centroide dell'area
Finding centroids for OGR layer ...
Sto scrivendo i centroidi...
ATTENZIONE: 127 areas represent more (overlapping) features, because
polygons overlap in input layer(s). Such areas are linked to more than 1
row in attribute table. The number of features for those areas is stored
as category in layer 2
36 poligoni di input
Area totale: 6.95028E+10 (511 aree)
Area di sovrapposizione: 3.39415E+09 (127 aree)
Aree senza categoria: 2.76545E-05 (111 aree)
Copying features...
Si sta ricreando la topologia per il vettore ...
1691 primitives registered
48681 vertices registered
Costruendo aree...
14..16..18..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
20..22..24..26..28..30..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
32..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
34..36..38..40..42..44..46..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
52..54..56..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
511 areas built
25 isles built
Isole allegate...
Centroidi allegati...
Numero di primitive: 1691
Numero di punti: 0
Numero di linee: 0
Numero di centroidi: 161
Numero di aree: 511
Numero di isole: 25
ATTENZIONE: The output contains topological errors:
ATTENZIONE: Unable to calculate a centroid for 239 areas
ATTENZIONE: Number of incorrect boundaries: 8
The input could be cleaned by snapping vertices to each other.
Estimated range of snapping threshold: [1e-08, 1]
Try to import again, snapping with at least 1e-08: 'snap=1e-08'
Copying features...
Costruendo aree...
511 areas built
25 isles built
Isole allegate...
Numero di punti: 0
Numero di linee: 0
Numero di aree: 511
Numero di isole: 25
Generalizzazione (douglas)...
Using threshold: 1000 meters
ATTENZIONE: 662 boundaries were not modified because modification would
damage topology
ATTENZIONE: 11 lines/boundaries were not modified due to
over-simplification
9975 vertices registered
Costruendo aree...
0..2..4..6..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
8..10..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
12..14..16..18..20..22..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
26..28..30..32..34..36..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
38..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
40..42..44..ATTENZIONE: Dimensione dell'area = 0.0 ignorata
511 areas built
25 isles built
Isole allegate...
Numero di punti: 0
Numero di linee: 0
Numero di aree: 511
Numero di isole: 25
v.generalize completo. Number of vertices for selected features reduced
from 48520 to 9814 (20% remaining)
Exporting 511 areas (may take some time)...
Warning 1: Value 1214165066.46143007 of field area of feature 0 not
successfully written. Possibly due to too larger number with respect to
field width
Warning 1: Value 1214165066.46143007 of field area of feature 1 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 2 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 3 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 4 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 5 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 6 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 7 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 8 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 9 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 10 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 14 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 19 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 20 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 21 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 22 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 23 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 24 not
field width
5..Warning 1: Value 1773729269.81201005 of field area of feature 25 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 26 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 27 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 28 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 29 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 30 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 31 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 32 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 33 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 34 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 35 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 36 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 37 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 38 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 39 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 40 not
field width
11..Warning 1: Value 1773729269.81201005 of field area of feature 41 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 42 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 43 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 44 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 45 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 46 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 47 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 48 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 49 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 50 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 51 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 52 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 53 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 54 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 55 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 56 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 57 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 58 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 59 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 60 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 61 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 62 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 63 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 64 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 65 not
field width
17..Warning 1: Value 3513367325.98779011 of field area of feature 66 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 67 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 68 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 69 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 70 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 71 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 72 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 73 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 74 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 75 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 76 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 77 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 78 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 79 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 80 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 81 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 82 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 83 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 84 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 85 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 86 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 87 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 88 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 89 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 90 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 91 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 92 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 93 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 94 not
field width
23..Warning 1: Value 365858607.909179986 of field area of feature 95 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 96 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 97 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 98 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 99 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 100 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 101 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 102 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 103 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 104 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 105 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 106 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 107 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 108 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 109 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 110 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 111 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 112 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 113 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 114 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 115 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 116 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 117 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 118 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 119 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 120 not
field width
Warning 1: Value 3234211964.6469698 of field area of feature 121 not
field width
29..Warning 1: Value 3234211964.6469698 of field area of feature 122 not
field width
Warning 1: Value 3819826697.02587986 of field area of feature 124 not
field width
Warning 1: Value 3819826697.02587986 of field area of feature 125 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 129 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 130 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 131 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 132 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 133 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 134 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 135 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 136 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 137 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 138 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 139 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 140 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 141 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 142 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 143 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 144 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 145 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 146 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 147 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 148 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 149 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 150 not
field width
35..Warning 1: Value 1773729269.81201005 of field area of feature 151
not successfully written. Possibly due to too larger number with respect
to field width
Warning 1: Value 964391185.716310024 of field area of feature 152 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 153 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 154 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 155 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 156 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 157 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 158 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 159 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 160 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 161 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 162 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 163 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 164 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 165 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 166 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 167 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 168 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 169 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 170 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 171 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 172 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 173 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 174 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 175 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 176 not
field width
41..Warning 1: Value 1773729269.81201005 of field area of feature 177
to field width
Warning 1: Value 964391185.716310024 of field area of feature 178 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 179 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 180 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 181 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 182 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 183 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 184 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 185 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 186 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 187 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 188 not
field width
47..Warning 1: Value 1773729269.81201005 of field area of feature 189
to field width
Warning 1: Value 964391185.716310024 of field area of feature 190 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 191 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 192 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 193 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 194 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 195 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 196 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 197 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 198 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 199 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 200 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 201 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 202 not
field width
53..Warning 1: Value 1773729269.81201005 of field area of feature 203
to field width
Warning 1: Value 964391185.716310024 of field area of feature 204 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 205 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 206 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 207 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 208 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 209 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 210 not
field width
Warning 1: Value 1773729269.81201005 of field area of feature 211 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 212 not
field width
59..Warning 1: Value 3513367325.98779011 of field area of feature 213
to field width
Warning 1: Value 964391185.716310024 of field area of feature 214 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 215 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 216 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 217 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 218 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 219 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 220 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 221 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 222 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 223 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 224 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 225 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 226 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 227 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 228 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 229 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 230 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 231 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 232 not
field width
65..Warning 1: Value 3513367325.98779011 of field area of feature 233
to field width
Warning 1: Value 964391185.716310024 of field area of feature 234 not
field width
Warning 1: Value 3513367325.98779011 of field area of feature 235 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 236 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 237 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 238 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 239 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 240 not
field width
71..Warning 1: Value 365858607.909179986 of field area of feature 241
to field width
Warning 1: Value 964391185.716310024 of field area of feature 242 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 243 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 244 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 245 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 246 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 247 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 248 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 249 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 250 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 251 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 252 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 253 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 254 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 255 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 256 not
field width
77..Warning 1: Value 365858607.909179986 of field area of feature 257
to field width
Warning 1: Value 964391185.716310024 of field area of feature 258 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 259 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 260 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 261 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 262 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 263 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 264 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 265 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 266 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 267 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 268 not
field width
Warning 1: Value 365858607.909179986 of field area of feature 269 not
field width
Warning 1: Value 964391185.716310024 of field area of feature 270 not
field width
83..Warning 1: Value 365858607.909179986 of field area of feature 271
to field width
Warning 1: Value 964391185.716310024 of field area of feature 272 not
field width
89..95..Warning 1: Value 3513367325.98779011 of field area of feature
274 not successfully written. Possibly due to too larger number with
respect to field width
Warning 1: Value 3234211964.6469698 of field area of feature 276 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 277 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 278 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 279 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 280 not
field width
Warning 1: Value 1214165066.46143007 of field area of feature 281 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 283 not
field width
Warning 1: Value 4505023165.16016006 of field area of feature 284 not
field width
Warning 1: Value 1155114462.08887005 of field area of feature 285 not
field width
Warning 1: Value 2444698110.21483994 of field area of feature 286 not
field width
100
Warning 1: Value 1214165066.46143007 of field area of feature 287 not
field width
ATTENZIONE: 350 features without category were skipped. Features without
category are written only when -c flag is given.
v.out.ogr completo. 288 features (Polygon type) written to
(ESRI_Shapefile format).
Execution of finished.
Cleaning up temporary files...
Converting outputs
Caricamento layer
Algorithm v.generalize.simplify - Vector based simplification
generalization. finished
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
