[GRASS-user] v.generalize failing on some geoms
Paolo Cavallini
cavallini at faunalia.it
Tue Feb 13 00:02:59 PST 2018
Hi Markus,
Il 12/02/2018 21:46, Markus Metz ha scritto:
> The original data in EPSG:3003 and EPSG:3857 are not identical. The
> original data in EPSG:3003 are topologically correct, while the original
> data in EPSG:3857 are not.
interesting. so reprojecting creates errors (tiny gaps, in fact). just
to document, the process was importing a shapefile into PostGIS, at the
same time reprojecting from 3003 to 3857
> Further on, the original data in EPSG:3857
> contain features that are not present in the original data in EPSG:3003
> which is quite strange.
forget about this, polygons added after import
> Reprojecting the original data in EPSG:3003 to EPSG:3857 within GRASS
> works fine, also with subsequent v.generalize.
> That means that the original data in EPSG:3857 are some reprojected
> version of the original original data (which are these?). The
> reprojection step, apparently performed on polygons, not GRASS areas
> (how did you reproject?), introduced topological errors. Please use
> native GRASS v.in.ogr + v.proj to reproject polygons.
right; an easy alternative when working with QGIS Processing is to add a
snap param, which cures the small gaps.
All the best, and thanks again.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
