[GRASS-user] load vector map from PostGIS
Markus Metz markus.metz.giswork at gmail.com
Wed Feb 14 09:01:07 PST 2018
On Wed, Feb 14, 2018 at 4:44 PM, Vilem Ded <Ded.V at seznam.cz> wrote:
> Thank you a lot. I have managed to move forward, but i am not there yet:/
> I can definitely reach the database since the command:
>  v.in.ogr -l input= "PG:host=172.21.3.20 dbname=mydb user=dbusername
password=passwd"
> prints out names of my tables in database.
> But command
> v.in.ogr input= "PG:host=172.21.3.20 dbname=mydb user=dbusername
password=passwd" output=outpoint  layer=myschema.mytable
> prints an error about "missing '=' after 'mydb' in connection info
string" (at the end). This seems maybe like pg error than grass.script,
doesnt it?
Try to reset the default GRASS db connection to the default (sqlite) with
db.connect -d
and test again
Markus M
> Thx.
> Vil
> DBMI-PostgreSQL driver error:
> Connection failed.
> missing "=" after "mydb" in connection info string
> Connection failed.
> WARNING: Unable to open database <dbname=mydb schema=myschema> by
>          driver <pg>
> WARNING: Unable open database <dbname=mydb schema=myschema> by
>          driver <pg>
> WARNING: Unable to find table <outputpoint> linked to vector map
>          <outputpoint>
> Creating attribute table for layer <myschema.mytable>...
> Connection failed.
> Connection failed.
>          driver <pg>
> ERROR: Unable to open database <dbname=mydb schema=myschema> by
>        driver <pg>
> ---------- Původní e-mail ----------
> Od: Moritz Lennert <mlennert at club.worldonline.be>
> Komu: Vilem Ded <Ded.V at seznam.cz>
> Datum: 13. 2. 2018 14:58:22
> Předmět: Re: [GRASS-user] load vector map from PostGIS
> Le Tue, 13 Feb 2018 14:09:31 +0100 (CET),
> "Vilem Ded" <Ded.V at seznam.cz> a écrit :
> > Hi,
> > is there any possibility to download data  into local grass database
> > (topologcal) from remote postgis server? (without getting error)
> > Or is the issue still pending?
> > (http://osgeo-org.1560.x6.nabble.com/Unable-
> > to-link-to-postgis-postgresql-td5285313.html) I am using Python to
> > work with GRASS. And honestly, I got lost in outputs of db.*
> > functions:
> AFAIK, you should not need to go through all the db.* functions to
> import your data. Not much time to look any further into this, but check
> this thread:
> https://lists.osgeo.org/pipermail/grass-dev/2017-May/085032.html/
> In brief, you should be able to import your data with a simple v.in.ogr
> call, without any db.connect/db.login magic.
> Moritz
> > #set database and login
> > gscript.run_command('db.connect',
> > database="host=172.21.3.20,dbname=mydb", driver="pg",  verbose = True)
> > gscript.run_command('db.login', user="dbusername", password="passwd",
> > overwrite = True)
> > #verifying connection
> > gscript.run_command('db.connect', flags='p')
> > output:
> > driver: pg
> > database: host=172.21.3.20,dbname=mydb
> > schema:
> > group:
> > #so everything looks fine so far
> > #here comes the trouble - simple list tables in db
> > gscript.run_command('db.tables', flags='p', verbose = True)
> > output:
> > Connection failed.
> > could not connect to server: No such file or directory
> >     Is the server running locally and accepting
> >     connections on Unix domain socket
> > "/var/run/postgresql/.s.PGSQL.5432"?
> > Connection failed.
> > ERROR: Unable to open database <host=172.21.3.20,dbname=mydb>
> > #but for example:
> > gscript.run_command('v.external',
> >                     input="PG:dbname=mydb host=172.21.3.20",
> >                     flags='l', overwrite =  True)
> > output:
> > --actuall list of all tables in mydb - so i CAN connect to the server!
> > #same for mapping external link - following will create external link
> > user=dbusername password=password",
> >                     layer="myschema.mytable", output='outpoints,
> > overwrite = True)
> > output:
> > WARNING: No key column detected.
> > WARNING: Feature table <outpoints> has no primary key defined. Unable
> > to define DB links.
> > WARNING: Random read is not supported for this layer. Unable to build
> >          topology.
> > v.external complete. Link to vector map <outpoints> created.
> > #weird, because i have primary key defined in the table, following is
> > printing description of that external link
> > gscript.vector_info("outpoints")
> > #if i try to load data from database
> > gscript.run_command('v.in.ogr',
> >                     layer='myschema.mytable',geometry="mygeomcolumn",
> > output = "outpoints2", overwrite =  True, type="point")
> > output:
> > Check if OGR layer <myschema.mytable> contains polygons...
> >  100%�����
> > WARNING: Vector map <outpoints2> already exists and will be
> > overwritten DBMI-PostgreSQL driver error:
> > Connection failed.
> > Connection failed.
> > WARNING: Unable to open database <host=172.21.3.20,dbname=macfishdb>
> > by driver <pg>
> > WARNING: Unable open database <host=172.21.3.20,dbname=macfishdb> by
> > driver <pg>
> > WARNING: Unable to find table <outpoints2> linked to vector map
> > <lp_grass> Creating attribute table for layer
> > <at_macfish.loggerpos>... DBMI-PostgreSQL driver error:
> > Connection failed.
> > Connection failed.
> > WARNING: Unable to open database <host=172.21.3.20,dbname=mydb> by
> >          driver <pg>
> > ERROR: Unable to open database <host=172.21.3.20,dbname=mydb> by
> >        driver <pg>
> > My version of grass:
> > GRASS version:
> > 7.4.0
> > GRASS SVN revision:
> > exported
> > Build date:
> > 2018-01-26
> > Build platform:
> > x86_64-pc-linux-gnu
> > GDAL:
> > 2.2.2
> > PROJ.4:
> > 4.9.2
> > GEOS:
> > 3.5.1
> > SQLite:
> > 3.11.0
> > Python:
> > 2.7.12
> > wxPython:
> > 3.0.2.0
> > Platform: Linux-4.4.0-112-generic-x86_64-with-Ubuntu-16.04-xenial
> > Version of python:
> > Python 2.7.12 64bits
> > Content of my .grass7/dblogin:
> > pg|host=172.21.3.20, dbname=mydb|dbusername|passwd||
sqlite|$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db|dbusername|passwd||
> > pg|macfishdb|dbusername|passwd||
> > pg|host=172.21.3.20,dbname=mydb|dbusername|passwd||
> > Thank you for any comment
> > Dead Vil
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180214/fe9c66b4/attachment-0001.html>
