[GRASS-user] LSMetrics - addon development
Markus Metz
markus.metz.giswork at gmail.com
Fri Feb 16 00:42:23 PST 2018
On Thu, Feb 15, 2018 at 10:38 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Feb 15, 2018 at 7:49 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
> > On Thu, Feb 15, 2018 at 5:57 PM, Markus Neteler <neteler at osgeo.org>
wrote:
> >> On Thu, Feb 15, 2018 at 5:43 PM, Moritz Lennert
> >> <mlennert at club.worldonline.be> wrote:
> >> > On 12/02/18 18:01, Bernardo Santos wrote:
> >> >> Regarding the comparison with the other GRASS tools, LSMetrics is
> >> >> complementary to many of the functions the r.li suite offers. I
still
> >> >> could
> >> >> not test r.pi since I had some trouble installing it, but I'll try
it
> >> >> again
> >> >> so that I can compare both packages. I believe they are also somehow
> >> >> complementary in many of the functions.
> >> > Yes, r.pi installation is still an issue.
> >> I have probably fixed it in r72243. Please try.
> >> But: I get this compilation error (probably easy to fix but I have no
> >> time right now):
> >> [mneteler at oboe r.pi.library ]$ make MODULE_TOPDIR=~/software/grass74
> >> gcc -shared -o
> >> /home/mneteler/software/grass74/dist.x86_64-pc-linux-gnu/lib/
libgrass_rpi.7.4.1svn.so
> >> -L/home/mneteler/software/grass74/dist.x86_64-pc-linux-gnu/lib
> >> -Wl,--no-undefined -Wl,-z,now -Wl,--export-dynamic
-Wl,-rpath-link,/home/mneteler/software/grass74/dist.x86_64-pc-linux-gnu/lib
> >> -Wl,-soname,libgrass_rpi.7.4.1svn.so OBJ.x86_64-pc-linux-gnu/draw.o
> >> OBJ.x86_64-pc-linux-gnu/frag.o OBJ.x86_64-pc-linux-gnu/helpers.o
> >> OBJ.x86_64-pc-linux-gnu/stat_method.o -lgrass_gis.7.4.1svn -lm -lm
> >> OBJ.x86_64-pc-linux-gnu/draw.o: In function `draw_line':
/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library/draw.c:38:
> >> undefined reference to `swap'
/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library/draw.c:39:
/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library/draw.c:43:
/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library/draw.c:44:
> >> collect2: error: ld returned 1 exit status
> >> make: *** [/home/mneteler/software/grass74/include/Make/Shlib.make:10:
libgrass_rpi.7.4.1svn.so]
> >> Error 1
> > swap is in draw.c L3-9
> Yes, I saw that - quite confusing that it does not compile (Fedora 27):
> > I can not reproduce this error. Do you have any changes in your local
copy?
> all clean and shiny
> > Maybe also try make clean, then make again, because
> yes done. So I get:
> [mneteler at oboe r.pi ]$ make MODULE_TOPDIR=~/software/grass74
> make -C r.pi.library || echo
> >> /home/mneteler/software/grass74/error.log
> make[1]: Entering directory
> '/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library'
> test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
> gcc -g -Wall -Wshadow -Wlogical-op
> -Werror-implicit-function-declaration -fPIC -fno-common -fexceptions
> -Wextra -Wunused -Waggressive-loop-optimizations -Wreturn-type
> -Wfatal-errors -march=native -std=gnu99 -fexceptions -fstack-protector
> -m64 -fPIC
-I/home/mneteler/software/grass74/dist.x86_64-pc-linux-gnu/include
> -DPACKAGE=\""grasslibs"\"
-DRELDIR=\"/home/mneteler/software/grass-addons/grass7/raster/r.pi/r.pi.library\"
> -o OBJ.x86_64-pc-linux-gnu/draw.o -c draw.c
> draw.c: In function ‘draw_point’:
> draw.c:11:62: warning: unused parameter ‘sy’ [-Wunused-parameter]
> void draw_point(int *map, int val, int x, int y, int sx, int sy, int
width)
> -m64 -fPIC
> -o OBJ.x86_64-pc-linux-gnu/frag.o -c frag.c
> -m64 -fPIC
> -o OBJ.x86_64-pc-linux-gnu/helpers.o -c helpers.c
> -m64 -fPIC
> -o OBJ.x86_64-pc-linux-gnu/stat_method.o -c stat_method.c
> gcc -shared -o
> Maybe my compiler flags matter?
I can't reproduce with your compiler flags. A wild guess: in draw.c:L3 try
to replace inline with static
Markus M
> markusN
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180216/feccf8b5/attachment-0001.html>
