[GRASS-user] Cannot re-install Grass 7.2
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Fri Feb 16 05:35:33 PST 2018
Dear list
I would like to go back from Grass 7.4 to Grass 7.2 (because the new
version is incompatible with QGIS). However, I have severe problems.
I am running Linux Mint 18.2****(Sonja).
When I try to add the correct ppa I get the following:
mira at mira-mint ~ $ sudo add-apt-repository ppa:ubuntugis/ubuntugis-stable
Cannot add PPA: 'No JSON object could be decoded'.
Changing the source manually in
/etc/apt/sources.list.d/ubuntugis-ubuntugis-unstable-xenial.list to
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-stable/ubuntu xenial main
deb-src http://ppa.launchpad.net/ubuntugis/ubuntugis-stable/ubuntu
xenial main
has the following effect when running sudo apt-get update:
... Err:16 http://ppa.launchpad.net/ubuntugis/ubuntugis-stable/ubuntu
xenial/main Sources
403 Forbidden
W: The repository
'http://ppa.launchpad.net/ubuntugis/ubuntugis-stable/ubuntu xenial
Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore
potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user
configuration details.
E: Failed to fetch
http://ppa.launchpad.net/ubuntugis/ubuntugis-stable/ubuntu/dists/xenial/main/source/Sources
403 Forbidden
E: Some index files failed to download. They have been ignored, or old
ones used instead.
Can anybody please point me into the right direction? Thanks a lot,
Mira
