[GRASS-user] Cannot re-install Grass 7.2
Mira Kattwinkel kattwinkel-mira at uni-landau.de
Fri Feb 16 06:01:40 PST 2018
qgis-plugin-grass depends on Grass 7.2, hence when I try to install it I
get the following message:
mira at mira-mint ~ $ sudo apt-get install qgis-plugin-grass
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  qgis-plugin-grass : Depends: grass722 but it is not installable
E: Unable to correct problems, you have held broken packages.
I think I cannot fix this from the QGIS side.
Best, Mira
On 16/02/18 14:48, Markus Neteler wrote:
> On Fri, Feb 16, 2018 at 2:35 PM, Mira Kattwinkel
> <kattwinkel-mira at uni-landau.de> wrote:
>> Dear list
>> I would like to go back from Grass 7.4 to Grass 7.2 (because the new version
>> is incompatible with QGIS).
> In which sense it is not compatibe? Better to fix that if needed.
> Markus
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
