[GRASS-user] python parse_command
Jonathan Reith
reith at mundialis.de
Mon Feb 19 07:41:21 PST 2018
Ok, now I understood the problem, thanks a lot Anna
But I'm still struggling with the parse_command and r.in.xyz
code-example:
compregion = grass.parse_command("r.in.xyz",input="tmp.xyz",
separator="space", flags="sg", output="bbox",
parse=(grass.parse_key_val,
{'sep': '='}))
print(compregion)
g.region(compregion,res="1", flags="p")
output:
{u'n': u'5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46'}
File "grass_scripts/rinopennrw.py", line 67, in <module>
File
"/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 626, in __call__
param.value = arg
File
"/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/parameter.py",
line 184, in _set_value
self._value, self._rawvalue = _check_value(self, value)
File
line 72, in _check_value
check_string(value)
File
line 42, in check_string
raise ValueError(msg % (param.name, type(value), value))
ValueError: The Parameter <region> require a string, <class
'grass.script.utils.KeyValue'> instead is provided: {u'n': u'5611999
The computional region is not correctly parsed. This part seems wrong:
...u'n': u'5611999...
I do not know where the < u' > is coming from and why it behaves like that.
I did the same command in GRASS itself and it looked like this:
>>> r.in.xyz -sg input=dgm1_05314000_Bonn_EPSG4647_XYZ/tmp.xyz
output=bla sep=space
n=5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46
Manually changing the compregion to the GRASS region i got the output
like this:
WARNING: Illegal filename <n=5611999 s=5610000 e=32361999 w=32360000
b=159.04 t=206.46>. Character <=> not allowed.
ERROR: Region <n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
t=206.46>
not found
File "grass_scripts/rinopennrw.py", line 68, in <module>
File
line 648, in __call__
return self.run()
File
line 769, in run
self.wait()
File
line 790, in wait
module=self.name, errors=stderr)
grass.exceptions.CalledModuleError: Module run g.region g.region
region=n=5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46
res=1 -p ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
This leads to the question, how the input for g.region should look like
in python?
Again, any help is appreciated :)
best regards
Am 19.02.2018 um 15:02 schrieb Anna Petrášová:
> On Mon, Feb 19, 2018 at 4:36 AM, Jonathan Reith <reith at mundialis.de> wrote:
>> thanks for the answers, but this did not work.
>> Again, here is my code, this time not just the minimum version:
>> #!/usr/bin/env python
>> import os
>> from grass_session import Session
>> from grass.script import core as gcore
>> from grass.pygrass.modules.shortcuts import general as g
>> from grass.pygrass.modules.shortcuts import raster as r
>> home= "/home/jreith/grassdata/nrw"
>> gisdb= "/home/jreith/grassdata"
>> loc= "nrw"
>> maps= "elevation"
>> epsg= "EPSG:4647"
>> xyz= "/home/jreith/geodaten/dgm1_05314000_Bonn_EPSG4647_XYZ/tmp.xyz"
>> if not os.path.exists(gisdb):
>> os.makedirs(gisdb)
>> if not os.path.exists(os.path.join(gisdb, loc)):
>> with Session(gisdb=gisdb, location=loc, create_opts=epsg):
>> print("Created a new location!")
>> else:
>> print("Location already exist!")
>> with open(xyz, "r") as t:
>> print(t.read())
>> with Session(gisdb=gisdb, location=loc, mapset="elevation", create_opts=""):
>> print("r.in_xyz works:")
>> r.in_xyz(input=xyz, output="new_file", flags="s",separator="space")
>> gisenvironment = gcore.parse_command("g.gisenv", flags="s")
>> print(gisenvironment)
>> compregion = gcore.parse_command('r.in_xyz', input=xyz, flags='s',
>> output="new_file",separator='space')
> You have to use r.in.xyz with gcore.parse_command as I suggested
> earlier. You are now using 2 different APIs, PyGRASS (where you use
> r.in_xyz) and Python Scripting Library (where you must use the real
> name of the command).
> Anna
>> This is my output:
>> GRASSBIN: grass74
>> GISBASE: /home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu
>> 32360000.00 5610000.00 170.55
>> 32360000.00 5610001.00 170.56
>> 32360000.00 5610002.00 170.58
>> 32360000.00 5610003.00 170.55
>> 32360000.00 5610004.00 170.58
>> r.in_xyz works:
>> Range: min max
>> x: 32360000 32360000
>> y: 5610000 5610004
>> z: 170.55 170.58
>> {u'MAPSET': u"'elevation';", u'GISDBASE': u"'/home/jreith/grassdata';",
>> u'LOCATION_NAME': u"'nrw';"}
>> File "grass_scripts/error_script.py", line 33, in <module>
>> File
>> "/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
>> line 516, in parse_command
>> res = read_command(*args, **kwargs)
>> File
>> line 471, in read_command
>> process = pipe_command(*args, **kwargs)
>> File
>> line 444, in pipe_command
>> return start_command(*args, **kwargs)
>> File
>> line 380, in start_command
>> return Popen(args, **popts)
>> File
>> line 74, in __init__
>> subprocess.Popen.__init__(self, args, **kwargs)
>> File "/usr/lib/python2.7/subprocess.py", line 711, in __init__
>> errread, errwrite)
>> File "/usr/lib/python2.7/subprocess.py", line 1343, in _execute_child
>> raise child_exception
>> OSError: [Errno 2] No such file or directory
>> I used a minimum example for the xyz-file. As you can see, there is no
>> problem with the location or database.
>> r.in_xyz is correct and also works itself. I also can parse the g.gisenv to
>> a variable and print it.
>> The problem is, that I cannot parse r.in_xyz to a new variable.
>> Maybe you have some hints for me :)
>> best regards
>> Jonathan
>> Am 12.02.2018 um 15:35 schrieb Pietro:
>> Dear Jonathan,
>> the error is due to grass_session that is not creating the location if
>> missing.
>> I don't have time in this day to fix this issue in grass_session, so the
>> fastest fsolution at the momenth is to check and create what is needed step
>> by step.
>> I did not have xyz file to test so I've only execute g.gisenv and it works,
>> let me know if it works also with r.inxyz:
>> ```python
>> from __future__ import print_function
>> import os
>> GISDBASE = "/tmp/grassdata"
>> LOCATION = "nrw"
>> EPSG = "EPSG:4326"
>> if not os.path.exists(GISDBASE):
>> os.makedirs(GISDBASE)
>> if not os.path.exists(os.path.join(GISDBASE, LOCATION)):
>> with Session(gisdb=GISDBASE, location=LOCATION,
>> create_opts=EPSG):
>> else:
>> with Session(gisdb=GISDBASE, location=LOCATION, mapset="elevation",
>> create_opts=""):
>> gcore.run_command("g.gisenv")
>> Best regards
>> Pietro
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180219/51319643/attachment-0001.html>
