[GRASS-user] Multiple `r.proj` requests on the same raster map(s)
Nikos Alexandris
nik at nikosalexandris.net
Sat Feb 24 12:25:26 PST 2018
Dear community,
I am asking for help to "debug" a situation.
One ETRS89-based location, one Mapset with hundreds of land cover raster
map tiles.
Then, hundreds of UTM Zones-based Locations, subset of the WRS2 grid.
Multiple `r.proj`es are running in parallel. However, only one at a time
from inside one Mapset inside the respective UTM-Zone-based Location,
requesting for one land cover raster map tile from the ETRS89-based Location.
And, each `r.proj` is isolated running inside an independent docker container.
To the question. Some tiles are cross-cut by more than one UTM-Zone.
Hence, it happens that many UTM-Zones will/might request to read the
same land cover raster map tile at the same time.
That is one write per target Mapset/Location, yet highly probable
concurrent read requests to the same raster map(s) in the source
Mapset/Location.
Is this bad?
Thank you, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180224/b4df2558/attachment.sig>
