[GRASS-user] python parse_command
Jonathan Reith
reith at mundialis.de
Mon Feb 26 01:53:55 PST 2018
Ok. So now my code is:
compregion = grass.parse_command("r.in.xyz", input=xyz,
separator="space", flags="sg", output="bbox",parse=(grass.parse_key_val,
{'sep': '='}))
print(compregion)
g.region(res="1", flags="p", **compregion)
and the output:
{u'n': u'5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46'}
ERROR: Invalid input <n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
t=206.46>
File "grass_scripts/error_script.py", line 40, in <module>
main()
File "grass_scripts/error_script.py", line 38, in main
File
"/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 648, in __call__
return self.run()
File
line 769, in run
self.wait()
File
line 790, in wait
module=self.name, errors=stderr)
grass.exceptions.CalledModuleError: Module run g.region g.region
n=5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46 res=1 -p
ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
It seems like my last error disappeared, but now I have a new one.
running < g.region n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
t=206.46 res=1 -p > from command line in GRASS works just fine.
Any help appreciated
Jonathan
Am 19.02.2018 um 18:49 schrieb Pietro:
> Thank you Anna I did not noticed the underscor...
> On 19 Feb 2018 4:41 p.m., "Jonathan Reith" <reith at mundialis.de
> <mailto:reith at mundialis.de>> wrote:
> print(compregion)
> g.region(compregion,res="1", flags="p")
> you are hassling the dictionary to a region, but you have to unpack
> the dictionary just write:
> the two * unpack the dictionary.
> Have fun!
> Pietro
Studentische Hilfskraft
mundialis GmbH & Co. KG
Firmensitz: Kölnstraße 99, 53111 Bonn
Registergericht: Amtsgericht Bonn, HRA 8528
vertreten durch: mundialis Verwaltungsgesellschaft mbH
Geschäftsführer:
Dr. rer. nat. Markus Neteler
Dipl.-Geogr. Hinrich Paulsen
Dipl.-Geogr. Till Adams
Tel. +49 (0)228 - 38 75 80 - 80
Fax. +49 (0)228 - 96 28 99 57
info [at] mundialis [dot] de
Internet: www.mundialis.de
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/7f9e657f/attachment.html>
