[GRASS-user] r.cross doesn't work correctly.
Gra
graziaz at gmail.com
Mon Feb 26 05:13:55 PST 2018
Hi
I tried also the -z flag.
I attach the result and the two inputs
Thanks
Grazia
2018-02-26 13:31 GMT+01:00 Nikos Alexandris <nik at nikosalexandris.net>:
> * Markus Metz <markus.metz.giswork at gmail.com> [2018-02-26 13:01:35 +0100]:
> On Mon, Feb 26, 2018 at 11:19 AM, Gra <graziaz at gmail.com> wrote:
>>> Dear community
>>> I use r.cross to combine and then reclassify a set of indicators.
>>> I realised that r.cross doesn't work correctly.
>>> I have two inputs maps with values from 1 to 3 each.
>>> the problem is that r.category doesn't list the first combination (eg 1
>> to 1)
>>> eg
>>> r.category map=myinput at in_data
>> 0
>>> 1 category 1; category 2
>>> 2 category 1; category 3
>>> 3 category 2; category 1
>>> 4 category 2; category 2
>>> 5 category 2; category 3
>>> 6 category 3; category 1
>>> 7 category 3; category 2
>>> 8 category 3; category 3
>>> in reality the first combination exists (0 is empty but I should have
>> there category 1; category 1)
>>> the problem is that I have to iterate on 700 cases and I wont check and
>> correct manually.
>>> could you fix it?
>> Please try trunk r72281
> Works for me, thank you.
> I get now (compared to what I've posted in the other post):
> 0 CZfg; category 1
> 1 CZfg; category 2
> 2 CZbg; category 1
> 3 CZbg; category 2
> 4 CZg; category 1
> What about the -z flag, though?
> r.category geology_Test
> 217 CZfg
> 405 CZbg
> 766 CZg
> r.category basins_0_12
> 0 0
> 12 Twelve
> r.cross input=geology_Test,basins_0_12 out=cross_Test_6
> r.cross input=geology_Test,basins_0_12 out=cross_Test_7 -z
> r.category cross_Test_6
> 0 CZfg; 0
> 1 CZfg; Twelve
> 2 CZbg; 0
> 3 CZbg; Twelve
> 4 CZg; 0
> and
> r.category cross_Test_7
> 0 CZfg; 0
> 1 CZfg; Twelve
> 2 CZbg; 0
> 3 CZbg; Twelve
> 4 CZg; 0
> The manual reads:
> With the -z flag zero data values are not crossed. This means that if a
> zero category value occurs in any input data layer, the combination is
> assigned to category zero in the resulting map layer, even if other data
> layers contain non-zero data. In the example given above, use of the -z
> option would cause 3 categories to be generated instead of 5.
> By the way, it should be: "In the following example..." and not "In the
> example given above...".
> Nikos
> Markus M
>> thanks
>>> Grazia
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/f20abe69/attachment-0001.html>
Type: application/x-java-pack200
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/f20abe69/attachment-0003.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/f20abe69/attachment-0004.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/f20abe69/attachment-0005.bin>
