[GRASS-user] Inconsistent number of column in the table
Daniel Victoria
daniel.victoria at gmail.com
Tue Jan 16 16:13:25 PST 2018
That is probably the case.
Is there a way to 'sanitize' this shapefile DBF prior to v.in.ogr?
Or the fact that v.db.select works on the CLI means that the attribute
table is OK. It's more a visualization problem with the GUI attribute table
manager.
Thanks
Daniel
On Tue, Jan 16, 2018 at 6:15 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> DanielV wrote
> > Hi List,
> > I imported a large vector shapefile into grass. v.in.ogr did not report
> > any
> > errors. However, when I try to open the attribute table (Show attribute
> > table in GUI dialog), I get an error saying "Inconsistent number of
> column
> > in the table". The Attribute table manager then opens but I can't browse
> > the data. However, table is correctly described (column names and data
> > type).
> > From the CLI, v.db.select will print the contents of the attribute table
> > without any complains.
> > Any idea how to troubleshoot this?
> are there any special characters in the table content, e.g. ' or " or ; or
> or / or \ .... etc?
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180117/4f43e432/attachment.html>
