[GRASS-user] d.legend in python loop draws larger background than requestes
Carlos Grohmann carlos.grohmann at gmail.com
Wed Jan 17 08:03:36 PST 2018
You mean providing the data for it?
I'm looping through 56 1x1degree DEMs, in about half of the cases the
legend gets the larger rectangle.
I used this same script before without any issues, the only difference is
that now I'm setting the range for the legend.
I tested it without the range parameter and it still gives the same
results. I'm setting up a virtual linux machine to test it, hoping it can
be something OSX-related...
Carlos
On Wed, Jan 17, 2018 at 10:26 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Jan 17, 2018 at 6:51 AM, Carlos Grohmann
> <carlos.grohmann at gmail.com> wrote:
> > Hello all
> > I'm producing some pngs for an article, using d.mon, d.grid and d.legend
> in
> > a python loop. In some of the images, the legend background is fine, but
> in
> > others, the background rectangle is way larger than what I defined.
> > This is an example of the loop:
> > araca = ['tdx12_Araca', 'tdx30_Araca', 'srtm30_Araca', 'aster30_Araca',
> > 'aw3d30_avg_Araca']
> > area_name = area[0].split('_')[-1]
> > for dem in area:
> >     grass.run_command('g.region', raster=dem, flags='pa', res='0:0:01')
> >     out_shade = dem + '_shade_315_20'
> >     grass.run_command('d.mon', start='png', output=dem+'.png',
> resolution =
> > '2', height=600, width=600, overwrite=True)
> >     grass.run_command('d.shade', shade=out_shade, color=dem)
> >     grass.run_command('d.grid', size='0.25', text_color='white',
> > color='white', border_color='white', flags='c')
> >     grass.run_command('d.legend', raster=dem, flags='sb', at='4,25,2,4',
> > font='Helvetica', \
> >         fontsize=12, bgcolor='240:240:240', range=(0,1500), units=' m')
> >     grass.run_command('d.mon', stop='png')
> >     print('PNG export OK. map: ' + dem)
> > This are examples of the results, note the legend background.
> > https://www.dropbox.com/s/skecv5lpxza7led/tdx30_Araca.png?dl=0
> > https://www.dropbox.com/s/szbmq5kqinfbiff/aster30_wgs84_Araca.png?dl=0
> > I've run this same script previously without any issues.
> > Any hints on why this is happening are greatly appreciated.
> not sure, I wonder if it's related to the fact it's latlon location.
> Would it be possible to create a reproducible example?
> Anna
> > Carlos
> > Prof. Carlos Henrique Grohmann
> > Institute of Energy and Environment - Univ. of São Paulo, Brazil
> > - Digital Terrain Analysis | GIS | Remote Sensing -
> > http://carlosgrohmann.com
> > http://orcid.org/0000-0001-5073-5572
> > ________________
> > Can’t stop the signal.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180117/bdfaedb2/attachment.html>
