[GRASS-user] [GRASS-dev] Grass on MacOS
Stuart Edwards
sedwards2 at cinci.rr.com
Thu Jan 18 10:08:21 PST 2018
Michael
I just clicked on the icon that I had moved to the Applications directory.
I can see wxpython in Resources/gui and there is a 'core' directory and a 'gui_core' directory - but I don't see a module named _core_ in the 'modules' directory.
Ironically, the green and yellow is a standard terminal theme option called 'Grass' (Terminal/Preferences/Profiles)
Stu
> On Jan 18, 2018, at 11:55 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Stuart,
> A couple of questions:
> 1. How did you try to launch GRASS?
> 2. Did you purposefully set your terminal to a green color or did this happen automatically? (I know it's weird but let me know).
> MIchael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton <http://www.public.asu.edu/~cmbarton>, http://csdc.asu.edu <http://csdc.asu.edu/>
>> On Jan 18, 2018, at 7:02 AM, Stuart Edwards <sedwards2 at cinci.rr.com <mailto:sedwards2 at cinci.rr.com>> wrote:
>> Hi -
>> Just tried to open the new package on a MacBook Pro running 10.13.2 (High Sierra) and got this message:
>> Starting GRASS GIS...
>> ERROR: wxGUI requires wxPython. No module named _core_
>> Thanks for all your efforts on this 'project'.......
>> Stu
>>> On Jan 17, 2018, at 5:14 PM, Michael Barton <Michael.Barton at asu.edu <mailto:Michael.Barton at asu.edu>> wrote:
>>> I've just posted a new GRASS 7.2.2 dmg to the GRASS for Mac web site (http://grassmac.wikidot.com <https://urldefense.proofpoint.com/v2/url?u=http-3A__grassmac.wikidot.com_&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=37ix_UbivXfbWCiQibwmgKBHRDRoVTZv7mZ1sfCb_-0&s=-GKTuCyzgWX4cqdp1QjXAY0sLPdSdSMfhwtNR1fXAZY&e=>). This one is compiled with gettext for internationalization. Please test.
>>> I have not been able to get 7.4 to compile yet.
>>> Michael
>>> C. Michael Barton
>>> www: http://www.public.asu.edu/~cmbarton <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=37ix_UbivXfbWCiQibwmgKBHRDRoVTZv7mZ1sfCb_-0&s=gwEH13w9qun-ClVo_dppH7DZoIqGk_pYDnSrbImNOeQ&e=>, http://csdc.asu.edu <https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu_&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=37ix_UbivXfbWCiQibwmgKBHRDRoVTZv7mZ1sfCb_-0&s=rVG5LaLrIHksRovyNA5MZLk46tpptIRx2ZoUggCo9l8&e=>
>>>> On Jan 16, 2018, at 9:37 PM, Michael Barton <Michael.Barton at asu.edu <mailto:Michael.Barton at asu.edu>> wrote:
>>>> Hi Helena,
>>>> I am very glad that it works for you so easily. A HUGE thanks is owed to Eric Hutton of the Community Surface Dynamics Modeling System (CSDMS), an NSF facility and scientific network for modeling in the earth sciences. It was Eric's idea to try this through Anaconda. He provided guidance and I worked though a lot of testing it as an Anaconda build last summer, but was unable to get it to a point where GRASS could reliably be compiled and then distributed. Over the last couple months, Eric has worked out how to solve those problems, including making a launchable app and packaging it all in a dmg. There is a bit of fine tuning left to do in the workflow, but it is essentially distributable now--making it the first time I've been able to create a stable and easily installable binary in a year and a half.
>>>> Parallel to this, Eric proposes (and has worked out the protocol) of also making GRASS available as an Anaconda package. He has created an Anaconda 'recipe' to do this. After getting the app/dmg distributed, I will follow his lead to test how this works as an alternative for those who use Anaconda for Python.
>>>> This new build has a couple of characteristics quite different from previous Mac versions. Most importantly, all needed dependencies are bundled inside the app. This makes for a bigger app, but hopefully eliminates any conflicts among dependency versions. No more separately installed "frameworks". No more conflicts if you (or a program) install another version of Python or wxPython somewhere. And hopefully, no more issues with Apple's 'system integrity protection' (SIP).
>>>> This test version does not include gettext for internationalization or libLAS. I wanted to test it as we've been developing the workflow, without adding anything else until I can confirm that it works. However, I think it will be easy to include gettext because there already is an Anaconda version available. LiDAR support may be trickier. I have previously compiled libLAS. I think it may be possible to work out how to link and bundle it in this Anaconda version. That said, there seems to be work in the dev team for substituting PDAL as a LiDAR support library, and Anaconda already supports PDAL. So if we can substitute PDAL functionality for libLAS functionality, we can do it all within an Anaconda environment.
>>>> This is also a full 64 bit version of GRASS. No more need to compile it dual architecture 32/64 bit. This solves a number of compiling and running issues, and means that the GUI now must run in wxPython 3 and above (still Python 2.7). There are several GUI bugs that show up in switching from wxPython 2.8 to 3+. I've created tickets on the 3 I know of. The most annoying 2 of these should be pretty easy to solve for the people who are actively managing the GUI (the menu button bar does not properly revert back to 2D buttons after displaying 3D, and a custom pull-down list control does not recognize mouse clicks). I don't know if the 3rd one is easy or difficult to solve (the interactive supervised classification module crashes GRASS).
>>>> Please feel free to distribute and get back in touch with me and Eric if you run into any issues.
>>>> Cheers
>>>> Michael
>>>> C. Michael Barton
>>>>> On Jan 16, 2018, at 6:53 PM, Helena Mitasova <hmitaso at ncsu.edu <mailto:hmitaso at ncsu.edu>> wrote:
>>>>> Michael,
>>>>> thank you for the dmg file - great news - I was able to get GRASS running on my new laptop in less than 10 minutes including download. On first double click it refused to open that it is not verfied but it allowed me to open it by clicking on it and selecting Open in the menu ( I remebered that trick from the past).
>>>>> I noticed that it does not have r.in.lidar (I am aware of the issue) but nviz and map swipe runs, g.gui.animation has a problem. Anyway it is fantastic to have GRASS Mac binary back - thank you all for the effort,
>>>>> Helena
>>>>> On Jan 16, 2018, at 6:08 PM, Michael Barton <Michael.Barton at asu.edu <mailto:Michael.Barton at asu.edu>> wrote:
>>>>>> Hi Eric,
>>>>>> I just started from scratch and compiled GRASS under Anaconda, created an app, and created a dmg. It runs with a double click. This is great!! Tonight, I will test on my laptop at home with SIP turned on. Fingers crossed.
>>>>>> Cheers
>>>>>> Michael
>>>>>> C. Michael Barton
>>>>>> www: http://www.public.asu.edu/~cmbarton <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=dkeB-ZwEUnUzUPDg3GviAwO4UuwwuVgxucWgLe6F9qk&s=1w-MJ9w4Erk8BK7WYjb276z_sPjXFTdZ55vhijfKYts&e=>, http://csdc.asu.edu <https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu_&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=dkeB-ZwEUnUzUPDg3GviAwO4UuwwuVgxucWgLe6F9qk&s=u8Mnc23Rg0THY5G7BvTF92f2I2ab-51FFzdA-_LYSNk&e=>
>>>>> Helena Mitasova
>>>>> Professor at the Department of Marine,
>>>>> Earth, and Atmospheric Sciences
>>>>> Associate director and faculty fellow at the Center for Geospatial Analytics
>>>>> North Carolina State University
>>>>> Raleigh, NC 27695-8208
>>>>> http://geospatial.ncsu.edu/osgeorel/publications.html <https://urldefense.proofpoint.com/v2/url?u=http-3A__geospatial.ncsu.edu_osgeorel_publications.html&d=DwMFaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=dkeB-ZwEUnUzUPDg3GviAwO4UuwwuVgxucWgLe6F9qk&s=zNLT_Z6rG3dZiCrrxSiPMKaKwpjLcuCLhX0gnmMRWoc&e=>
>>>>> "All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/grass-user <https://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/caf63461/attachment-0001.html>
