[GRASS-user] d.vect output a black PNG
Anna Petrášová
kratochanna at gmail.com
Thu Jan 18 15:59:25 PST 2018
Have you tried cairo driver? I feel like I've seen something like this
before with PNG driver.
Anna
On Thu, Jan 18, 2018 at 5:46 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> Hello all
> Continuing my process of making a series of maps for a paper using python
> loops and d.mon with PNG outputs, now d.vect is giving me a hard time.
> using a loop like this one:
> for dem in dems:
> out_shade = dem + area + '_shade_315_20'
> vect_contour = dem + area + '_contours_zoom'
> grass.run_command('g.region',n=n,s=s,w=w,e=e, flags='pa')
> grass.run_command('d.mon', start='png',
> output=dem+area+'_shade_contours.png', \
> resolution='3', height=500, width=500, overwrite=True)
> grass.run_command('d.rast', map=out_shade)
> grass.run_command('d.vect', map=vect_contour, type='line')
> grass.run_command('d.grid', size='0.025', text_color='black',
> fontsize=16, flags='c')
> grass.run_command('d.mon', stop='png')
> I get maps that are ok, some that are partially blacked out and some that
> are completely black!
> Any hints on this? The area in the images below is quite small, and the
> contour lines were calculated only in this small region, to keep the
> filesize small.
> I tried this on MacOS (homebrew and Michael's new binary) and on Linux,
> with the same results.
> many thanks
> Carlos
> [image: Inline image 1][image: Inline image 2][image: Inline image 4][image:
> Inline image 5][image: Inline image 3]
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180118/312cfae6/attachment-0009.png>
